- Mar, 24 Feb 2009 21:54
#798691
Hola que tal
me podrian decir el por que tan barato ????? este heli
yo entiendo que nadie regala nada pero no todo lo barato es basura
alguien lo conoce o tiene algun dato
son 99 dolares + envio algo sobre 26 dolares
http://site.xheli.com/18H53ARF.jpg
http://site.xheli.com/18H53ARF_11.jpg
http://site.xheli.com/18H53ARF_2.jpg
http://site.xheli.com/18H53ARF_3.jpg
http://site.xheli.com/18H53ARF_5.jpg
http://site.xheli.com/18H53ARF_6.jpg
Disculpen no se pegar fotos
datos del heli :
Key Features
Extreme 3D capability right out of the box
95% factory-assembled
Direct-to-swash CCPM linkages
Stacked aluminum frames
Aluminum and composite swashplate
Tail servo boom mount
Stainless steel tail rotor hub
325mm PRO symmetrical plastic main blades
Belt-driven tail rotor
Auto-rotation system
Gun-metal gray aluminum head block
Gun-metal gray aluminum skids and tail boom
Overview
The EXI 450 uses a combination of tough, lightweight aluminum and updated composite parts and is designed and equipped to be capable of the most extreme 3D maneuvers right out of the box. And since it痴 95% assembled, you can have it flying in just a few hours.
Specs
Main Rotor Diameter:27.6 in (700mm)
Tail Rotor Diameter:5.9 in (150mm)
Gross Weight:22?4 oz (620?80 g)
Length:25.6 in (650mm)
Kit/ARF
por que quiero este y no el align no se es mas bonito y 30 dolares menos
gerardo[/img][/url]
datos del heli :
Key Features
Overview
Specs
Kit/ARF
gerardo[/img][/url]
