- Jue, 25 Abr 2013 22:26
#1213668
Hola.
Segun el manual de la Wren 80 Jubilee, por poner un ejemplo, el fabricante recomienda todos estos aceites. Uno de ellos, es el que citas.
To the fuel must be added 5% of a suitable oil, i.e. a mixture of around 20:1 fuel to oil. Suitable oils are turbine oils such as Mobil JetOil, Aeroshell 500/550 and Exxon 2380. Other oils specifically for use in turbine engines and which will mix readily with the fuel and stay mixed may also be used. For example
Castrol TT 2 stroke motor cycle oil and oils used for outboard motor engines have been used very successfully.
At Wren we use Mobil DTE Light, a clear non-hazardous hydraulic oil which requires no special handling precautions, generates no carcinogenic vapours when used in the engine and has no significant environmental impact. Its only real disadvantage is it is only available in large 20ltr drums but, of course, friends can club together and get a good supply in the one container.
Mobil DTE Light is available from the larger tool and hardware suppliers.
Yo por ejemplo, en la Wren 44 Turboprop, utilizo el Castrol Power 1 TTS, y sin problemas, te sale casi a mitad de precio que el que citas y va perfecto, el unico inconveniente es que si la dejas parada mucho tiempo (meses), posiblemente le cueste realizar el primer arranque por que tiene los rodamientos engomados, pero sin mas.
Pepe.-
