- Lun, 13 Dic 2004 22:15
#21130
En reyes me quiero pillar un heli, y mirando por internet encontrado
este heli, T-REX 450X 3D EP. me parece interesante su precio .
Va con motor 400S brushless, 20A ESC and 400GYRO HH gyro.
Que opinais de el...
Enri
Adjustable pitch system
Hold rotate system
Tail rotor drive belt system
High efficiency main rotor
High efficiency tail rotor
Rear tail servo mount
Super iron main shaft
High Rigidity aluminum tail boom
Super iron landing skids
High strength carbon fiber tail boom brace
Specifications:
Length: 630mm
Height: 230mm
Main rotor: 640mm
Tail rotor: 150mm
Weight: 320g (without power)/600-650g (with power)
Motor Gear: 13T/11T
Main Gear: 150T
Hold rotation gear: 109T
Tail gear: 22T
Gear drive ratio: 1:11.5:4.95/1:13.6:4.95
Pictures:
Enri
Hold rotate system
Specifications:
Length: 630mm
Height: 230mm
Main rotor: 640mm
Tail rotor: 150mm
Motor Gear: 13T/11T
Main Gear: 150T
Tail gear: 22T
Pictures:
Proximo proyecto: miss wind s 50e
Fusion (Depron desmontable)
Angels 30e
Helios 25
Biplano depron
JR PCM9X II
Angels 30e
Helios 25
Biplano depron
JR PCM9X II
