Enrique Royo escribió:Hola , normalmente por aquí le colocamos los 81mg y caben bien .
Creo que no necesitas mas fuerza.
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.11sec/60° at no load
Operating Speed (6.0V): 0.09sec/60° at no load
Stall Torque (4.8V): 36.10 oz/in. (2.6kg.cm)
Stall Torque (6.0V): 41.66 oz/in. (3kg.cm)
Operating Angle: 40 Deg. one side pulse traveling 400usec
360 Modifiable: No
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 8.8mA/idle and 220mA no load operating
Current Drain (6.0V): 9.1mA/idle and 280mA no load operating
Dead Band Width: 8usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Direct Drive
Bearing Type: None, outer case serves as bearing
Gear Type: All Nylon
Connector Wire Length: 6.29" (160mm)
Dimensions: 1.17" x 0.47"x 1.16" (29.8 x 112 x 29.6mm)
Weight: 0.58oz (16.6g)
Operating Speed (4.8V): 0.16sec/60° at no load
Operating Speed (6.0V): 0.14sec/60° at no load
Stall Torque (4.8V): 41.66 oz/in. (3kg.cm)
Stall Torque (6.0V): 48.6 oz/in. (3.5kg.cm)
360 Modifiable: No
Current Drain (4.8V): 8mA/idle and 240mA no load operating
Current Drain (6.0V): 8.6mA/idle and 260mA no load operating
Bearing Type: Single Ball Bearing
Gear Type: All Nylon Gears
Dimensions: 1.14" x 0.51"x 1.18" (29 x 13 x 30mm)
Weight: 0.77oz (21.9g)
