muchas gracias, entonces este motor iria mejor:
http://www.unitedhobbies.com/UNITEDHOBB ... oduct=2140
key usb para variador
https://www.unitedhobbies.com/UNITEDHOB ... oduct=2119
variador (me sirve para mis lipos de 2 elementos y 7,4 ¿creo?
http://www.unitedhobbies.com/UNITEDHOBB ... oduct=4314
Speed Controller Features
High rate (10 KHz) switching (PWM)
2 to 4 Li-poly cells with receiver.
Dynamic braking ensures prompt prop folding.
BEC (2.0A) provides power to receiver and servos.
Over temperature protection.
User programmable Features.
Low-voltage protection - Programmable
Cutoff can be programmed for motor stop or reduced power.
Brake Type.
Throttle Range.
Timing Advance.
Safe “power on” arming program.
Low torque “soft start” prevents damage to fragile gearboxes.
Auto shut down in 4sec after signal is lost or radio interference becomes severe.
Microprocessor controlled.
Programmable rotation.
Specifics;
Max Load : 40A
Voltage Range : 2-4 cell
BEC: 2A
