Por fmendo
#842680
He estado mirando por el foro pero no he conseguido encontrarlo,
Alguien tiene la configuracion a poner en una DX7 para el cp belt.
Muchas gracias.
Por Aleks
#842789
Pues yo tengo una configuración que encontré en RCGroups está en ingles pero ojala te sirva
Saludos!
DX7 Setup Guide for belt tail heli (120 deg swash)
________________________________________
DX7 SETUP FOR BELT HELI
* Before setting up, bind your receiver to the transmitter. This is done by plugging the bind plug into the BATT socket in the receiver. Then plug the battery to the esc and/or bec. Then press the transmitter bind button at the back as you turn on the transmitter. Wait for the flashing receiver lights stabilize. When it has bound, the esc will arm. You can release the bind button. Turn off the transmitter and unplug the heli’s battery. Remove the bind plug from the receiver.
I. System Setup Mode
1. Enter the System Setup Menu by pressing Scroll Down and Select keys while turning on the transmitter.
2. Press UP or Down keys to navigate.
3. Go to [TYPE SELECT] and choose HELI for your model.
4. Go to [MODEL SELECT] and assign a model number for your heli. Use the Increase or Decrease keys to toggle between choices.
5. Go to [MODEL NAME] to assign a custom name. Use Increase or Decrease to select letter. Press Select key to move to next letter.
6. Then press the Down key to go to [SWASH TYPE] menu. Use Increase or Decrease key to toggle to 3 SERVOS 120º.
7. Next go to [INPUT SELECT] menu by toggling UP or Down keys. It should be
AUX2>AUX2 and GEAR>GEAR.
II. Function Mode
1. Enter the Function Mode menus by pressing Down and Select keys after turning on the transmitter.
2. Use the UP or Down keys to toggle between menus.
3. Go to [REVERSING SW] menu to set your servo reversing switches.
Ch1 : Throttle (esc)
CH2: Aileron (left cyclic servo)
CH3: Elevator (front or rear single cyclic servo)
CH4: Rudder (gyro)
CH5: Gear (gyro remote gain cable)
CH6: Aux1 (right cyclic servo)
*Note that this is for individual servo reversing. For collective cyclic reversing, go to [SWASH MIX] menu.
4. Go to [SWASH MIX] Menu. Use Select button to toggle between functions.
5. Initially set AILE, ELEV at 100%. – or + values changes the servo directions. Set PIT value so that you get maximum + and - pitch without bottoming mechanically or have the servos buzzing. Again – or + values reverses the collective direction.
6. Leave EXP in INH.
7. Go to [TRAVEL ADJUST]. Use Select key to toggle between functions.
8. For THRO, set High (H) value just high enough so you get a max motor output (ESC led flashes) at max stick input. At times, this can be less than 100%. Set Low (L) value just low enough that the esc arms. At times, this is less than 100%. This provides best throttle resolution.
9. AILE, ELEV, and PIT. adjusts the cyclic servo maximum throw. Always adjust all three pairs of H and L in identical values. Values for AILE, ELEV, and PIT. must also be identical. This ensures no unneeded output interaction when controlling the cyclic action. You can adjust these to give you more or less cyclic angles. Max these out without having the servos buzzing. Recheck these settings after centering the servo arms at mid stick using the [SUB TRIM] menu.
10. Adjusting the RUDD endpoints, controls the piro rate not the servo throw. Remember that the servo receives a command signal rather than a proportional
signal. Adjust L and R piro rates so that you get the same piro rate turning left or right. IT is normal to exceed 100% for both values.
11. GEAR is used to adjust gyro gain. + value is hh mode. – value is rate mode. Set these initally at +72% and -28%. Readjust after a test hover.
12. AUX2 is unused for now. The channel is unavailable in the AR6100. The switch, however can be assigned to a function like throttle hold. This frees up the use of the Rudder D/R switch for other functions like dual piro rates.
13. Go to [SUB TRIM] menu.
14. Adjust AILE subtrim to center the left cyclic servo in mid throttle stick.
15. Adjust ELEV subtrim to center the front or rear single cyclic servo at mid stick.
16. Adjust PIT. Subtrim to center the right cyclic servo.
17. Adjust the RUDD subtrim if servo arm drifts in hh mode during tests.
18. Leave [AUTO D/R EXP] in default settings for now.
19. Go to [D/R & EXP] menu. Use Select keys to toggle between functions. Use Increase or decrease to change channel and change values.
20. Expos if used changes command sensitivity. + values makes command less sensitive. Lower value down to a negative value increases sensitivity. More sensitivity makes the heli twitchy. Full stick, however always yields the maximum programmed servo throw.
21. AILE and ELEV expos affect the cyclic. RUDD affects the piro or turn rate.
22. D/R adjusts the maximum servo arm travel of the affected functions. Reducing AILE and ELEV rates for example reduces the maximum swash plate angles. These can be toggled in flight using the marked D/R switches. Leave these at 100% for now for both on and off switch positions of the various D/R switches.
23. Note that you have two switch positions for both expo and dual rates. Toggle the
actual physical switches when setting values for each switch position. It will be indicated in POS-1 or POS-0.
24.Go to [PITCH CURVE] HOLD. Use Select key to move between throttle positions. Use Increase or Decrease keys to change values. This menu sets the main blade pitch range when the Throttle hold switch is turned on. This gives you maximum positive and negative pitch. This is useful for setting blade pitch using a pitch gauge. Mid stick is zero degrees.
25. Note that 0 to 50% gives you negative pitch. 50% to 100% gives you positive pitch. 0% is maximum negative pitch. For most helis this is -10 deg.
26. In HOLD position, set pitch range as 0-INH-50%-INH-100%.
27. Go to [PITCH CURVE] ST-2. This is for 3D. Set this for maximum head speed and fast collective response for flipping, tic tocs, etc. The S-curve is ideal for this.
28. Set ST-2 at 0-15%-50%-85%-100%. This is an S-curve. Pitch rapidly changes around the mid stick for fast vertical transitions.
29. Go to [PITCH CURVE] ST-1. Let’s keep this linear. Set it at 0-INH-50%-INH-100%. This give a smooth and predictable collective response. This is good for sport flying and mild aerobatics.
30. Go to [PITCH CURVE] NORM. Let’s dial out negative pitch or at least most of it for proper spool up. You can put a few degrees of negative pitch if desired. I prefer zero on spool up. Set this at 50%-50%-50%-INH-100%. This gives zero degrees pitch up until mid stick. Then pitch increase above it.
31. Go to [THRO CURVE] ST-2. You can keep this flat for max head speed. Or use a conservative v-curve for moderate speed. I use 100%-INH-80-INH-100%.
32. Go to [THRO CURVE] ST-1. Set this so that you get a comfortable hovering speed. I set this at 100%-INH-60-INH-100%.
33. Go to [THRO CURVE] NORM. Keep this linear unless you have an unusual motor response. Set this at 0-INH-50%-INH-100%.
34. Go to [THRO HOLD]. Use Select key to toggle between throttle hold value and desired activating switch. Set throttle value at -5.%. It is a negative value to ensure that the throttle is zero in case the esc setting drifts. Choose your desired switch. I selected SW: RUDD D/R simply because I am used to that position. You can use AUX2 if you wish to use the RUDD D/R for dual piro rate control.
35. After all settings are final, bind your receiver to the transmitter once more while keeping the transmitter sticks in your desired failsafe settings. This does away with the cyclic servos being crooked and buzzing while the receiver arms.
36. Fine tune after your test flight.
37. Go fly your heli! Congratulations.
Por fmendo
#843300
Muchas gracias a los 2 a ver si soy capaz de configurarla si alguien mas tiene algo pues todo es de agradecer.
Muchas gracias y un saludo
Por fmendo
#844834
Aleks gracias por tu respuesta pero no es lo que busco puesto que no es la configracion para el cp belt si no el como se configura la emisora.
Vuelvo a lo mismo alguien tiene la configuracion de la DX7 para el cp belt?
Muchas gracias
Por bellido
#845093
yo tengo la de la dx6i en un t-rex 450, si te vale
es la misma de la dx7 y las jr y las graupner mx 12,16
Por fmendo
#845108
Creo que si que me valdrá para hacerme una idea a ver si hago vida del heli.
Muchas gracias
