Hola,quiero contruirme el Buswacker,en carton-pluma,pero veo que en los planos,la electronica que és requerida,(al ser un poco antiguos los planos,inmagino)al buscar el motor por exemplo en las webs,no soy capaz de encontrarlo,quizás esté obsoleto.Soy novato,y no soy capaz de encontrar una electronica equivalente,actual,para este modelo.Los servos,ya estan pedidos,en la web bangood,pero el motor,esc,y la bateria,(de 3S),no se cual comprar,para no quedarme justito.Os adjunto el enlace de la web de contruccion.Gracias de antemano
https://www.flitetest.com/articles/ft-bushwacker-build
#1403657
Pack B:
FliteTest https://store.flitetest.com/flite-test- ... 34/p846360
Banggood https://m.banggood.com/Racerstar-BR2212 ... mds=search
Pack C:
FliteTest https://store.flitetest.com/flite-test- ... 36/p846362
Banggood
https://m.banggood.com/EMAX-GT2215-09-1 ... mds=search
Batería: cualquier lipo 3S entre 1800mah/2200mah
Esc: cualquier de 35A 2S/4S
Nota de FliteTest: The FT Bushwacker is an aerobatic super short take off/landing aircraft. For extreme 3D aerobatic performance, use the large control surfaces. For extreme super STOL performance, split each aileron in half to create flaps. This plane is designed for intermediate to advanced pilots and is capable of most aerobatic maneuvers with the Power Pack C. With the Power Pack B, the Bushwacker is capable of basic aerobatics and is a little more docile.
The Bushwacker isn’t much of a beginner plane, however with just a few hours under your belt on the FT Tiny Trainer or the FT Storch, flying the Bushwacker will come very naturally to you!
