- Jue, 15 May 2008 9:56
#670859
Buenas, entre estos dos receptores, en las caracteristicas, nos pone en el R617FS full range y en el R616FFM Limited Range, Indoor este segundo sería apto para vuelo exterior en un electrico 450.
gracias
Receiver R617FS
Manufacturer Futaba
Special Features Pre-Vision Screening Scan
Modulation 2.4GHz FASST shifting
Channels 7
Range Full Range
Voltage 4.8-6V
Dimensions 40mm x 27mm x 9.5mm
Weight 10g
Shift -
Crystal -
Receiver R616FFM
Manufacturer Futaba
Channels 6
Range Limited Range, Indoor
Voltage 4.8-6V
Dimensions 38mm x 22mm x 7mm
Weight 6.5g
Shift -
Crystal -
gracias
Receiver R617FS
Manufacturer Futaba
Channels 7
Range Full Range
Voltage 4.8-6V
Weight 10g
Shift -
Crystal -
Receiver R616FFM
Manufacturer Futaba
Channels 6
Voltage 4.8-6V
Weight 6.5g
Shift -
Crystal -
TREX 500
REX600.12s
ALA LLANERA
ROBBE _ ARCUS
ION PRO - FLAPS
SWISH TOPMODEL
WATTS - RC 35-70C
A VOLAR!!!!
http://aeromodelismo.creatuforo.com/
REX600.12s
ALA LLANERA
ROBBE _ ARCUS
ION PRO - FLAPS
SWISH TOPMODEL
WATTS - RC 35-70C
A VOLAR!!!!
