- Sab, 28 May 2005 13:26
#66907
Insisto otra vez, esto es lo que pone en los comentarios de los servos futaba de alto par:
This is the Futaba S3305 High Torque, Metal Gear Servo.
per Futaba this servo is approved for use with NiCd batteries ONLY!
This servo can produce high-current draw from your batteries.
If using NiMH or Li-Po batteries, make sure they are capable
of delivering sufficient Amps.
Entonces...no se deben usar baterias de NiMh?
