Por DominicZe
#904171
Pues eso he leido muchas contradicciones, unos dicen que tiene, otros que no y otros que el problema es que se tiene que configurar.
Yo por más que lo intento no se como configurarlo, consigo cambiarle el freno, el tipo de batería etc... pero nada sobre lo del BEC. Alguien sabe a ciencia cierta que es eso del BEC Opto Only?
El cacharro en sí es este: http://www.hobbyking.com/hobbycity/stor ... 40-50A_ESC
Gracias y un saludo.
Por sukoi
#904208
si miras en la pagina web de referencia ( la del motor de hobyking ) veras en los comentarios de los otros comprado el siguiente acerca de la programacion :
SUP 50A ESC
David Bacon |
Bought 2, installed 1, and I found complete programming info elsewhere, so now I have it running fine. Do a search for "50 Amp Esc" and you might find the answers as I did.
Don't give up until you have located the programming sheet and set it up properly.
Also make sure you supply proper control voltage, as it doesn't have BEC. I started with 6V, and it would beep-out complaints, 4.5V seems to work fine. Just in case you don't want to find the programming info, I will see if it fits in this review:
1. TAKE OFF PROP!!!
2. Turn on Rec, ESC, then Xmit with throttle on full, listen to beeps:
3. Musical tone, then 1 beep indicates that battery type can be programmed. This is repeated three times, then same but 2 beeps, then 3 beeps, 4, 5, and 6, all repeated three times, and it starts all over again. When you hear the one you want, go to 1/2 throttle. Here is what they mean:
ONE=Battery
TWO=Throttle
THREE=Brake
FOUR=Direction & Cutoff
FIVE=Timing
SIX=PWM setting
4. Next you select the choice within that option, with beeps coded to say where you are, again each choice is repeated three times, and when you hear the one you want, go back to full throttle, here they are: (Short-Long)
1-1 = NiCd
1-2 = 7 cell LiPo
1-3 = 6 cell LiPo
1-4 = 5 cell LiPo
1-5 = 4 cell LiPo
1-6 = 3 cell LiPo
1-7 = 2 cell LiPo
2-1 = Auto throttle range
2-2 = 1.1ms to 1.8 ms from Recvr
2-3 = Accelerate Fast
2-4 = Accelerate by ramp-up
3-1 = No brake
3-2 = Soft brake
3-3 = Med
edito :mrgreen: , el BEC opto only te indica que NO tiene BEC :roll: , por lo que como te dice el colega, tienes que alimentarlo con bateria aparte para poder programarlo
Por DominicZe
#904214
Ya podían haber puesto: No bec o algo más clarito... de todas formas he encontrado otros comentarios que dicen que significa que se tiene que programar, por eso preguntaba, me tienen liadito perdío XD
