Joder, mira que sois vagos
¿para que esta san google?
http://www.sigmfg.com/
menu airplanes, menu biy, hog-bipe
.60-.65 cu. in. 2-Stroke
.65-.90 cu. in. 4-Stroke
Top Wingspan: 54 1/2 in.
Bottom Wingspan: 51 3/4 in.
Total Wing Area: 966 sq. in.
Weight: 7 to 8 lbs.
Radio Required: 4-Channel
Nothing Flies Like A Hog . . .
Since 1957, thousands of modelers have been delighted with the slow flying, yet fully aerobatic, flight performance of the original ASTRO-HOG. As the old saying goes, “Nothing flies like a Hog!”. Well, now you can have the same easy flying aerobatic performance in a sport biplane design - the SIG HOG-BIPE.
Just like the ASTRO-HOG, the HOG-BIPE performs any maneuver in the book, yet flies slow enough to let you enjoy it. This is barnstorming at its best!
The HOG-BIPE kit is fast building and easy to assemble. Computer accurate parts that fit together perfectly make it easy for the average builder to successfully assemble an accurate, straight flying biplane. The large photo-illustrated instruction book takes you through every step of the assembly.
Extensive Prefabrication:
38 Laser Cut Parts
Pre-Shaped Leading Edges
Pre-Shaped Trailing Edges
Pre-Shaped Ailerons
Pre-Shaped Elevators
Pre-Shaped Rudder
Fully-Symmetrical NACA Airfoil
Complete Hardware Pack
CAD Drawn Full-Size Plans
Quick Building Lite-Ply Fuselage
Built-Up Balsa Wings
Formed Aluminum Landing Gear
Formed Aluminum Cabane Struts
Molded ABS Plastic Headrest
Molded ABS Plastic Wheel Pants
Engine Mounts
SIG Easy Hinges
Complete Pushrods
Photo-Illustrated Instruction Book
