Efectivamente el gps tracker con tarjeta de movil pasan de 80 gr de peso, no nos sirve, a no ser que sea un velero de 5 m.
Ya he descubierto lo mejor y lo usan en vuelo libre F1A veleros A2, buscar free flight radio beacon, esto ultimo es radiobaliza, estas si que pesan poco, menos de 3 gr, incluso 1,3 g, pero es un producto caro, para buscar hablan de una receiver pero junto dos radibalizas vale 330 €, os pongo los datos del vendedor. Segun se mire, no es tan caro, seguro que es lo mejor.
PRICE LIST-----PRICE LIST-----PRICE LIST-----PRICE LIST
October 2004
MODEL RETRIEVE BEACONS AND TRANCEIVERS.
Locating your model with a model retrieve beacon (transmitter/tracker) is today essential. If you have a small transmitter in your model, you can locate your model at distances of 500-1000 meters. Lost models are unknown for model retrieve transmitter users. An exception is of course a total "fly-away" although models have been located at distances of 50 km. or more. Retrieving models can be done up to two weeks or more depending on the type of battery you use.
"If you start to use a model retrieve beacon, you know how much you suffered before!"
BEACONS
• With integrated batteryholder for BR425/435 3 volt Lithium battery.
Size 13 X 17 X 6 mm. Battery plugs into Beacon. Weight 3.0 gr. with battery
Battery life at least 14 days continuous operation (BR435).
• Without a battery, with wires for separate battery connection
Size 8 X 16 X 6 mm. Weight 1.3 gram without battery can also be used for further encapsulation.
• Round, fit Russian models. Size 9 X 21 mm. Battery plugs into Beacon.
Weight 3.0 gram with battery.
Prices: per beacon:
1 beacon, incl. 2 batteries Euro 80,--
2 - 4 beacon at the same freq. Incl. 1 battery per Beacon Euro 75,--
5 or more at the same freq. Euro 70,--
Prices are including package and postage.
Unlimited warranty on workmanship.
• Beacon small repair, replacement antenna, batt. holder etc. Euro 15,--
including packing, postage and 2 batteries (Mirae BR435).
Defective electronics and crystal will be replaced at cost price.
Please specify with order your frequency (any frequency) and the model Beacon you need. All new Beacons produced by me have unique frequencies. If you never had an assigned frequency I will assign one. Lothar Doring and I have exchanged frequency lists to avoid two flyers at the same frequency. New frequencies will be assigned according to this list. Be aware that all frequencies between 140 and 160 MHz. Are assigned. If you need a new frequency I will assign a frequency, which is shared by a flyer far from your area.
Lead-time for beacons approx. one month (Xtal made to order).
I keep beacons with new frequencies in stock, also Starter kits.
Aqui los receivers
TRANSCEIVERS
HORA C150 (Standard C150) Transceiver, with battery case Euro 195,--
Transmitting from 130MHz. – 174 MHz., 5 Watt max. (12 volt)
Receiving from 130MHz. - 174 MHz. 20 channel memory
Sensitivity less than 0,2 microvolt
Transceiver has a battery case for 6 AA type batteries
Dimension 55(w) x 31(d) x 124(h) mm. With batterycase
Transceiver modified for extended frequency range and “S” meter for short pulses
HORA C150 with 7,2 volt Nicad pack and 220 volt charger Euro 230,--
ALINCO DJ-196 Transceiver Euro 245,--
Receiving from 130MHz. - 174 MHz. 40 channel memory
7,2 volt Nicad batterypack and wall charger included
Dimension 56(w) x 40(d) x 124(h) mm. With Ni-Mh batterypack
Accessories for the HORA C150
Leatherette case Euro 15,--
Nicad battery 7,2 volt , 700 Mah. Euro 35,--
Charger 220 volt Euro 15,--
Accessories for the YAESU 411
Nicad battry 12 volt, 600 Mah. Euro 35,--
For new starters with model retrieve systems I offer so-called Starterkits.
HORA C150 Transceiver with one beacon Euro 265,--
HORA C150 Transceiver with two beacons Euro 330,--
HORA C150 Transceiver with three beacons Euro 395,--
Alinco DJ-195 Transceiver with two beacons Euro 380,--
Alinco DJ-195 Transceiver with three beacons Euro 445,--
Each additional beacon Euro 65,--
Beacons are at one frequency additional freq. Each Euro 5,00
ANTENNAE
Telescope “Long Ranger Euro 25,--
Rubberduck replacement Euro 31,75
Yagi HB9CV with cable and plugs Euro 65,--
BATTERIES
Lithium battery "Mirae" BR-435" 2 for Euro 2,00
3.0 volt, cap. 40mah. 4 X 35mm. Weight 0.8gr.
Lithium battery "Mirae" BR-425" 2 for Euro 2,00
3.0 volt, cap. 20mah. 4 X 25mm. Weight 0.6gr.
Packing and postage not included for articles on this page. I prefer to deliver and payment at the flying site.
Bank information:
P. Ruyter, Hoevelaken, Netherlands.
IBAN: NL54 PSTB 0006 7082 56 ,
BIC: PSTB NL21,
Using the IBAN number will give you a bankcharge free money transfer within the Euro area.
For checks outside Euro area add. Euro 15, - for bank charge.
For cash in a letter use a (good sealed with tape) registered letter.
New address:
Kantemarsweg 36
3871 AP Hoevelaken
Netherlands
Telephone: +31 33 2581459
E-mail:
pim.ruyter@planet.nl
JM
