- Dom, 19 Oct 2008 15:28
#737057
Hola, necesito que alguien que domine el ingles me traduzca este parrafo al castellano. Gracias:
The engine stalls when accellerated =Highend needle way too lean, or lowend needle slightly lean
Four strokes as fast idle, mid RPM =Lowend needle too rich, float diaphragm needle lever slightly too high
Engine goes lean in flight =Highend needle slightly lean AND lowend needle is rich, float needle lever may be set too low
Engine goes rich in flight= this is a special problem with cowled in engines. the float diaphragm cover vent will need work (SEE NOTE 1)
Engine runs good, but no idle at all= There's crap in the idle jets, the carb will have to be removed and cleaned. You may also have an air leak at the base of the carb. The throttle butterfly could be damaged or worn out.
carb leaks fuel when not running= float needle is bad or has crap stuck in it, or the float lever setting may be too high, or the float diaphragm is bad.
My engine four cycles momentarily when I back off the throttle, then runs normal = This is perfectly normal for carbs NOT equipped with a "check valve" highspeed jet. If you do have the check valve, then your float needle setting is slightly too high, or your float needle is leaking a little.(SEE NOTE 2)
the fuel leaks back into the gas tank when it isn't running =Bad fuel pump membrane, or an air leak in the fuel line at the carb
Yo soy del equipo "Jaarrr, no siento las piernasss".
Y piloto oficial de mis aviones.No te jode.
