- Jue, 14 Ago 2008 11:11
#711469
hola, mi pregunta es como se comuta un BEC externoque tiene la posibilidad de funcionar a 5v y tambien a 6v , es que yo no le veo ningun interruptor, eso si lleva dos salidas de tres pins , una la utilizo la otra no se si es para otro voltaje ,aquí os dejo una foto y las especificaciones, saludos
1.1 Output Voltage: 5V or 6V (Changeable with an output-voltage select switch )
1.2 Continuous output current: 3 Amps
1.3 Input: 5.5V-23V (2-5 cells lithium battery pack or 5-15 cells NiMh /NiCd battery)
1.4 Size: 42mm*17mm*7mm (length*width*height)
1.7 Weight: 11g
2 Features
2.1 Designed with an advanced switch mode DC-DC regulator IC.
2.2 The output is powerful.
2.3 With the output short-circuit protection function.
2.4 A metal shield covers almost all the electronic components, and a specially made filter is attached with the output wires to significantly reduce the electromagnetic interference.
2.5 Shows the working status with an indicator (LED), lights when the output is in normal range.
1.7 Weight: 11g
2 Features
T Rex 550-MicrobeastX + DS650,DS610 x 3,CC100A ,600M
QuadPro by Graphite74
Futaba 8J+Futaba 6J
Quanum Nova,Tarot 2D, 9443 Carbon, OSD, Landing Gear Carbon, 4000 Mha.
<Graphite74>
http://rc.runryder.com/helicopter/gallery/60760/
Futaba 8J+Futaba 6J
<Graphite74>
