- Lun, 01 Dic 2008 20:38
#756538
Ahora tengo otra duda...
Tengo dos pack de baterias de Ni-Cd de 10 elementos c/u (12V) y 2400 mAh que quiero cargar y descargar a la vez con este cargador:
Accucel8150
Turnigy Accucel-8 150W 7A Balancer/Charger
The Accucel-8150 is a Lipoly/LiFe battery charging workhorse. Capable of handling up to 8S, 7A or a maximum of 150W charging current plus balancing and discharging packs.
The Accucell has various programming and charging modes. It will accept and safely charge NiCd,Lilo, Lipo, LiFe, Pb batteries.
Spec.
Operating voltage range: 11.0~18.0Volt
Circuit power: max. 150W
Charge current range: 0.1~7.0A
Discharge current range: 0.1~5.0A
NiCd/NiMH battery cell count: 1~27 cells
Lithium bettery cell count: 1~8 Series
Pb battery voltage: 2 to 36V
Weight: 625g
Dimensions: 170X125X35mm
La pregunta es: Como los conecto,entre si, en serie para sumar Voltaje o en paralelo para sumar Amperaje?
Accucel8150
Spec.
Weight: 625g
Nunca hay mal que por bien no venga.
