- Dom, 27 Mar 2011 1:44
#1038013
Hola.
Quie me podria decir que regulador utilizar con este motor.
GT2218-09 Motor BRUSHLESS última generación 1100kv OUTRUNNER
Length: 36,5mm
Diameter: 28,5mm
Weight: 80g
KV: 1100
Battery: Li-po 2-3S
Shaft diameter: 4mm
Prop: 10x4.7 12x6
Max Watt: 312W
Max Thurst: 1380g
Model Weight 600-1200g
Reference:YY-GT2218-09
Length: 36,5mm
Diameter: 28,5mm
Weight: 80g
KV: 1100
Battery: Li-po 2-3S
Shaft diameter: 4mm
Prop: 10x4.7 12x6
Max Watt: 312W
Max Thurst: 1380g
JR Propo-XG 14
Gaui X7
Gaui x7 Formula
Gaui X5
Blade 130 X
MCPX BL
Hisky FBL 100
Gaui X7
Gaui x7 Formula
Gaui X5
Blade 130 X
MCPX BL
Hisky FBL 100
