- Vie, 17 Nov 2006 22:57
#346206
hola amigos:
Alguien conoce este aparato?
Según parece, aparte de aumentar las funciones en dos posibles canales, sirve de secuenciador de trenes, cabinas. Fail-safe de trenes y para lo que se quiera, se programa con el programador de Orbit y lo podeis ver en la web de Orbit.
www.orbitronic.de
________________________________________
The Orbit JETRONIC-BOX is a universal R/C processor for use in medium-sized and large model aircraft. Two R/C inputs can be pro-grammed to control up to three R/C outputs, for example to implement a landing gear with door control or a cockpit with open/close and lock functions, where even an R/C transmitter with microprocessor control is not sufficient.
Two R/C- and position-switch inputs
Compressed air input 0-10 bar with failsafe-function
Three programmable R/C-outputs
EDT display-terminal connection
Programmable Info-LED for in-, outputs and air pressure
Integrated voltage display for the receiver with memory-function
nanoWatt processor with ESD-protection
USB-lead for firmware updates available
W x H x D: 50 x 35 x 20 mm
Weight: 24 g
Supply: 4,8 - 7V / ca. 20 mA
Manual PDF (1050 KB)
Accessories:
Jetronic2USB PC-Interface [0825]
Onboard micro EDT [0832]
Jetronic EDT [0830]
PRO Zweikreis-Fahrwerksventil [0981]
Best.Nr. // Item No.: 0288
Preis // Price: 92.50 EUR
____________________________________________
Tiene un precio chulo, pero si hace todo lo que dice, me parece barato, ya que solo el Fail-safe de Tamjets cuesta algo similar y solo es un Fail-safe de trenes.
www.orbitronic.de
Weight: 24 g
Accessories:
Jetronic EDT [0830]
