lletisso escribió:Gracias por las respuestas, pero...creeis que con el 30 podria hacer un vuelo normal..? sin pedirle segun qeu maniobras..?
Muchas gracias!
hola si este es tu kit te puedes fijar lo que requiere en motor
REQUIRES: Engine:
Gas 2.5-4.1 cu in (41-70cc)
Glow 2.1-2.8 cu in (35-45cc) (do not recommend 5 cyl radial)
Propeller: Specific to engine purchased, display prop in photo on box
is handmade for display only, for flying, a 2-bladed prop is
suggested because they are more efficient.
Engine Mount, 5" Spinner, Fuel Tank 32oz, Gas or Glow Fuel-
Tubing 36", Easy Filler Fuel Valve for Gas or Glow,
Radio: 6-7 Channel
Servos: 3 Standard
(1-throttle, 1-tailwheel steering, 1-for retracts)
7 High Torque (45 oz-in minimum)
(2-ailerons, 2-flaps, 2-elevator, 1-Rudder)
Y-Harness: 4 (1-ailerons,1-flaps,1-elevator,1-rudder/tailwh steering)
Servo Wire Extensions (24"): 2
Switch and Charge Mounting Set, Heavy-Duty Control Horns
Receiver Battery: 6V, 1200mAh
Retracts: Main (ROBQ1655) Tailwheel (ROBQ2230)
Covering: Five Plus 6 Foot Rolls
Fuelproof Paint: Top Flite LustreKote
Misc. Items: Two 5" Main Wheels, One 1¾" Tailwheel, ½" Thick
Foam Rubber Padding (HCAQ1050), Twenty-Nine Heavy-Duty Hinge Points
Sixteen #6 ½" Sheet Metal Screws (for mounting the retracts),
1/4 to 1/5 scale Pilot Figure, Building and Field Equipment.
A Pull-Pull Cable System for the Steerable Tailwheel
y si es arf
REQUIRES: Radio: 7-channel minimum
Servos: Three standard, eight high torque
Standard Servo for Air Control Valve (if using retracts)
Standard Servo for Throttle
Standard Servo for optional Choke
Two Servos w/at least 99 oz-in torque for Elevators
Two Servos w/at least 99 oz-in torque for Rudder
Two Servos w/at least 99 oz-in torque for Ailerons
Two Servos w/at least 99 oz-in torque for Flaps
Servo Extensions:
24" (610mm): Four heavy duty for ailerons and flaps
6" (152mm): Two heavy duty
Y-Harness: Three depending on reciver and number of channels used
Receiver Battery: At least 1000mAh
Engine: 3.0 - 4.0 cu in (50 - 55cc) gasoline powered
Building and field equipment
por eso digo de donde sacas que un 30 cc levantara tu avion de 2.2 mt de envergadura , para mi es una locura ni siquiera levantara del piso es una realidad lo que te estoy tratando de decir un abrazo saludos
