- Mar, 26 Jul 2005 18:39
#88357
Alguien sabe algo de este Heli, tiene una pinta chulisima, todo en Aluminio, etc.
Por las dimensiones tiene pinta de poder aprovechar muchas piezas para tunear otros helis (el HB en mi caso)
Os dejo la web donde lo he visto
http://www.himodel.net/rc_hobby/helicopters_1021.php
![Imagen](http://www.himodel.com/en/p_img/CyberCopter_2.jpg)
![Imagen](http://www.himodel.com/en/p_img/CyberCopter_3.jpg)
Features:
THIS IS THE LATEST VERSION OF CYBERCOPTER 3D CCPM ELECTRIC HELICOPTER
The performances, stability and control are excerlent.
- Rotor head and tail rotor completely of aluminium, for higher precision
- Double ball bearing: blade holder
- Double ball bearing: main mast
- Double ball bearing: tail rotor
- Double ball bearing: tail boom
- 3 points CCPM swashplate mounted on ball bearing
- Rotor head with cyclic pitch enables aerobatic flights
- Underlying Bell/Hiller flybar system for less tracking
- Chassis and RC plate in light and strong epoxy fibers
- SX-plates, gyro and ESC are integrated in the chassis
- Tailrotor servo mounted on the tail boom
- Tail boom in aluminium with quick fixation
- Landing gear completely in aluminium
- Blocking pin on swashplate for higher precision
- Solid main gear with large teeth
Specifications:
Length w/blade 736 mm ( 29" )
Body Length 533 mm ( 21" )
Height 216 mm (8-1/2")
Rotor Diameter Main - 584 mm (8-1/2")
Tail - 123mm (4.9")
Gear Ratio 101 : 1 4.5 : 1
Flying Weight 550g (19.4 oz.) with motor, battery & radio
Engine 380 motor (included)
Rotor blade ABS(included)
![Wink :wink:](https://www.miliamperios.com/foro/images/smilies/icon_wink.gif)
Features:
Specifications:
Tail - 123mm (4.9")
