- Mié, 12 Dic 2018 4:16
#1392014
DJI Mavic Air 4K Camera
El link: http://bit.ly/2PymSEv Precio:641.59
Si quieren los cupones, contactenme, por favor.
Aircraft:Takeoff Weight: 430 g
Dimensions: Folded: 168×83×49 mm (L×W×H)
Unfolded: 168×184×64 mm (L×W×H)
Diagonal Distance: 213 mm
Max Ascent Speed: 3 m/s (S - mode[1])
2 m/s (P - mode)
2 m/s (Wi-Fi mode)
Max Descent Speed: 2 m/s (S - mode[1])
1.5 m/s (P - mode)
1 m/s (Wi-Fi mode)
Max Speed (near sea level, no wind): 68.4 kph (S - mode[1])
28.8 kph (P - mode)
28.8 kph (Wi-Fi mode)
Max Service Ceiling Above Sea Level: 5000 m
Max Flight Time (no wind): 21 minutes (at a consistent 25 kph)
Max Hovering Time (no wind): 20 minutes
Max Flight Distance (no wind): 10 km (at a consistent 25 kph)
Max Wind Speed Resistance: 29 - 38 kph
Max Tilt Angle: 35°(S - mode[1])
25°(P - mode)
Max Angular Velocity: 250°/s (S - mode[1])
250°/s (P - mode)
Operating Temperature Range: 0°C - 40°C
Operating Frequency: 2.400 - 2.4835 GHz
5.725 - 5.850 GHz
Transmission Power (EIRP): 2.400 - 2.4835 GHz
FCC: ≤28 dBm
CE: ≤19 dBm
SRRC: ≤19 dBm
MIC: ≤19 dBm
5.725 - 5.850 GHz
FCC: ≤31 dBm
CE: ≤14 dBm
SRRC: ≤27 dBm
GNSS: GPS + GLONASS
Hovering Accuracy Range: Vertical: ±0.1 m (with Vision Positioning)
±0.5 m (with GPS Positioning)
Horizontal: ±0.1 m (with Vision Positioning)
±1.5 m (with GPS Positioning)
Internal Storage: 8 GB
2 m/s (P - mode)
2 m/s (Wi-Fi mode)
1.5 m/s (P - mode)
1 m/s (Wi-Fi mode)
28.8 kph (P - mode)
25°(P - mode)
250°/s (P - mode)
5.725 - 5.850 GHz
FCC: ≤28 dBm
CE: ≤19 dBm
SRRC: ≤19 dBm
MIC: ≤19 dBm
5.725 - 5.850 GHz
FCC: ≤31 dBm
CE: ≤14 dBm
SRRC: ≤27 dBm
GNSS: GPS + GLONASS
