- Sab, 03 Nov 2012 19:59
#1175873
La batería que debe llevar el cdi, ¿debe ser mayor o menor de 1200mah?
? Displacement: 30.5cc
? Output Power:7HP/8500rpm
? Idle Speed: 1600rpm/min
? Static Thrust:8.5KG Pulling Force/ 100 meters Altitude, 7.5KG Pulling Force/1800 meters Altitude
? The specification of the aircraft propeller: 18*8 18*10 19*8 20*8
? The type of the sparking plug: NGK CM6
? Exhaust Amount: 30.5cm3
? Diameter stroke:36mm*30mm
? Ratio of compression: 7.6:1
? Ratio of lubricating capacity: 30:1
? Weight: Main engine-910g. Exhaust Pipe-60g
? Ignition equipment-120g
? Fuel: 2C Regular Gasoline mixed 30:1(Mineral based for breakin, synthetic thereafter)
? Propeller: 18x8 ; 18x10 ; 19x8 ; 20x8
? Ignition Battery: 4.8 - 6.0v (max) <= 1200mah
? Types of the Spark Plug: NGK CM6 or quivalent
? Plug Gap: 0.018" to 0.020
? Installation Torque: 7 to 8 ft-lbs
GRACIAS.
GRACIAS.
Última edición por jlmm36 el Dom, 04 Nov 2012 10:26, editado 3 veces en total.
