Me ha picado la curiosidad y he mirado el manual a ver que ponia sobre esto:
To set a Throttle Cut position, select INH under THRO Cut by rotating the Scroll Bar and click on it to toggle between
activated (ACT) and inhibited (INH). If Intelligent Throttle Trim has been previously activated, it will be inhibited
automatically. Select the figure below THRO Cut by rotating the Scroll Bar and click on it to bring up the sub menu. The
highlighting is surrounded by a box to indicate that it is selected. The default cut throttle position is -12% corresponding to
a servo position about 25% below the normal Throttle low position. Figures between ± 25% may be entered with -25%
corresponding to the absolute minimum servo movement and +25% corresponding to 50% above the normal tick-over
position. Rotate the Scroll Bar to alter the setting. When the required setting is achieved, click the Scroll Bar to exit the sub
menu. The clear (CLR) key at the left side of the screen returns the setting point to the default of -12%.
Please note that the position set is an absolute servo position. If the Throttle Digital Trim is set to a value below
the set figure, the CUT switch will increase the Throttle position rather than decrease it.
(Fuente: Manual de la JR PCM9xII, pagina 60)
Mi ingles es francamente malo, asi que a ver si alguien se anima a hacer la traduccion..
. Si no, ya la pondre yo mas o menos.
Saludos..
