- Lun, 16 Jun 2008 12:16
#688772
Pues tengo una duda sobre este variador. lo que quiero saber es si al iniciar determina la posicion del gas como punto medio,o por el contrario hay que llevar el stick al minimo para que inicie, y el minimo es el punto medio, nose si me he explicado, Datos:
hexTronik PRO 120A BESC w/ PC Programmability
Speed Controller Features
High rate (10 KHz) switching (PWM)
3 to 6 Li-poly cells with receiver.
Dynamic braking ensures prompt prop folding.
BEC (2.0A) provides power to receiver and servos.
Over temperature protection.
User programmable Features.
Low-voltage protection - Programmable
Cutoff can be programmed for motor stop or reduced power.
Brake Type.
Throttle Range.
Timing Advance.
Safe “power on?arming program.
Low torque “soft start?prevents damage to fragile gearboxes.
Auto shut down in 4sec after signal is lost or radio interference becomes severe.
Microprocessor controlled.
Programmable rotation.
Brake Type.
Throttle Range.
Timing Advance.
