Important Product BulletinHaving trouble viewing this email? Click here.
May 25, 2011
Spektrum and JR DSMX Transmitter Bulletin
DSMX transmitters operating in DSM2 mode
The Spektrum Team has been investigating sporadic
reports from DSMX transmitter owners using their
products in DSM2 mode. We have discovered that in some
rare instances, DSMX equipped transmitters with the
Product ID (PID) within this bulletin, may have a
backwards compatibility issue that could cause a "hold"
with the following superseded DSM2 receivers: AR500,
AR6100, AR6100E, AR6110, AR6110E, AR6200 and AR6300.
Note: This bulletin does not apply to DSM2 ONLY
transmitters.
If you have a DSMX transmitter with one of the following
PIDs, please complete the Transmitter Service Request
Form to receive a prepaid shipping label to send your
transmitter to Horizon Hobby for a free firmware update.
Click HERE to complete the Transmitter Service Request
Form.
Horizon will pay for ground shipping within the United
States and Canada.
If you purchased your product outside the US and
Canada, contact your local retailer or distributor. A
list of International distributors may be found HERE.
If you have further questions in the United States,
please call Horizon Hobby Product Support at
877-504-0233.
The PID is located in the battery compartment of your
transmitter.
DX6i/DX5e/DX4e:
PID: HS010, HS011, HH011, HT011, HT012, HE012, HE101,
HA101, HA102, HA103, HA104, HA105
Transmitters with affected PIDs may be found in the
following products:
Blade mCP X RTF (BLH3500), E-flite Apprentice 15e RTF
(EFL2725), Hangar 9 Alpha 40 DSM2 RTF (HAN4400),
Hobbyzone Super Cub DSM RTF (HBZ7400), ParkZone Radian
RTF (PKZ4700), ParkZone P-51D BL DSM RTF (PKZ2200),
ParkZone F4U Corsair RTF (PKZ4600), Phoenix R/C Pro
Simulator 3.0 with DX5e (RTM30R5510/RTM30R55101).
DX8:
PID: HS008, HS009, HH009, HH010, HT010, HE010, HE011,
HA011, HA012, HA101, HO102, HO103, HO104, HO105
DX7:
PID: HA103, HA104, HA105
JRP9503:
PID: TM101, TM102, TM103, TM104, TM105
JRP9303:
We apologize for this inconvenience. Horizon disclaims
all liability and warranties for any consumer failing to
act upon this product bulletin. Always check your
transmitter and equipment prior to each flight.
Spektrum DX8 Gimbal Bulletin:
Spektrum Product Development has been investigating
reports from DX8 transmitter customers experiencing
servo movements inconsistent with corresponding
transmitter stick input.
As a precautionary measure, Horizon Hobby would like DX8
customers to perform the Monitor Test to examine Gimbal
controls over the entire range of each axis of input.
Expected results for the Monitor Test should show smooth
tracking with corresponding stick input. If the Monitor
"jumps", hesitates, or is seen in a channel other than
what is being tested, please follow the Monitor Test
instructions below to test DX8 Gimbal movement:
Monitor Test:
Step 1: Turn on power switch. Ensure left stick position
(throttle) is low and Flap/Gyro switch is in position 0
or all the way up.
Step 2: Press the roller to enter the Function List
menu.
Step 3: Using the roller, scroll to the bottom of the
Function List menu and depress roller to select Monitor
function.
Step 4: Note the position of the Aileron (AIL) and
Rudder (RUD) positions. Ensure all trims are centered
and sub-trims are zero before continuing to Step 5.
Step 5: Move the Throttle (Left side) and Elevator
(Right side) gimbals up and down being very careful not
to touch the control sticks. While moving the gimbals up
and down, note the AIL and RUD positions on the Monitor.
ONLY touch the Gimbal on the outer frame where shown,
being very careful not to move the stick as this will
falsify the test.
Step 6: If the percentage for the Aileron or Rudder
changes by more than 3%, follow the instructions for
sending your DX8 transmitter in for inspection.
DX8 Transmitter Service Request:
Form.
States and Canada.
877-504-0233.
© 2011 Horizon Hobby.
The Spektrum trademark is used with permission of Bachmann
Industries, Inc.
DSM2 and DSMX are trademarks of Horizon Hobby, Inc. JR is a
trademark of Horizon Hobby, Inc., registered in the U.S.
If you no longer wish to receive this newsletter, you may
unsubscribe
Please send any questions, comments, or concerns to
webmaster@spektrumrc.com
Mailing Address: Horizon Hobby, Inc., 4105 Fieldstone Rd.,
Champaign, IL 61822
