Hola ,que les parece este eje de acero con cabeza de aluminio para el Esky lama ,creen que sea buena idea ,por $20 Dlls ,espero sus comentarios,gracias
Description:
-The InnerShaft and Aluminum Main Rotor Hub for Blade CX / Lama 2 is designed to improve the strength of the stock innershaft and stock plastic main rotor hub. The new innershaft and main rotor hub includes a new strong steel innershaft, a bigger and stronger steel spindle shaft and a precision CNC aluminum main rotor hub. This system not only reduces the chance of broken main rotor hub and innershaft but also provides a new great look for your blade CX and Lama 2.
Includes:
-CNC aluminum main rotor hub
-Steel spindle shaft
-Steel innershaft
-All screws and two allen keys included
