Por vinci
#896315
Hola a todos ......pues eso que tengo una emisora 4 ex que utilizo para el simulador y me da la impresion que se ha bloqueado en la forma de vuelo "V" ¿¿¿¿¿eso es posible?????
Bueno pues ese es mi problema si alguien conoce una solucion me haria un gran favor gracias de todos modossaludos vinci
Por itanu
#896319
puede ser..
Puedes desactivar la opcion leyendo el manual... o borrar el modelo y hacer uno nuevo.
Total para el simulador no necesitas ninguna impostación especial.
Venga... edito y te pongo el punto del manual donde lo explica.
Está en ingles.
Si necesitas traducción me lo dices
Wing Mixing Type Selection
There are two different wing mixing functions to select from:
V-tail mixing
Intended for V-tail aircraft (such as a Beechcraft Bonanza), V -tail mixing allows the
ruddervators to operate both as rudders and elevators. V -tail mixing requires that
each ruddervator be operated by a separate servo.
To activate V-tail mixing:
1. Connect the left ruddervator servo to channel 2 (elevator) in the receiver and
connect the right ruddervator servo to channel 4 (rudder) in the receiver.
2. Enter the programming mode. Access the “WING” screen with the MODE key.
3. Push the DATA INPUT lever upward or downward for about a half second to select the V-tail
mixing.
You cannot set “V-tail” mixing when “Elevon” mixing has already been set.
4. Once this mix has been activated, move the servos to their full extremes to make certain they are not overdriving the
controls. If necessary, adjust the linkages to achieve the correct control throws.
Elevon mixing
Intended for tailless, “flying wing” models such as delta wings and flying wings,
elevon mixing mixes channel 1 (aileron) to channel 2 (elevator) allowing the
elevons to operate in unison (as elevators) or in opposition (as ailerons). This
function requires that each elevon be operated by a separate servo.
To activate elevon mixing:
1. Connect the servo in the right wing to channel 2 (elevator) in the receiver and connect the
servo in the left wing to channel 1 (aileron) in the receiver.
Elevon mixing.
You cannot set “Elevon” mixing when “V-TL” mixing has already been set.
Por vinci
#896598
Gracias itano, por responder....pero tengo el manual en castellano sigo todos los pasos y no hay forma de quitar la V
ademas que ni yo he puesto esa opcion de vuelo
La otra opcion borrando todos los datos tampoco funciona ...ademas que la v esta en los cuatro modelos que puedo configurar
Por itanu
#896610
Que raro... a ver si llega alguien y nos aclara porque no es normal que borrando los modelos siga haciéndotelo...
Por GATOO
#1266750
hay alguna manera de combinar dos frecuencias en la emisora para poder pasar de 4 canales a 8 con dos receptores?
