- Sab, 12 Dic 2009 17:40
#896319
puede ser..
Puedes desactivar la opcion leyendo el manual... o borrar el modelo y hacer uno nuevo.
Total para el simulador no necesitas ninguna impostación especial.
Venga... edito y te pongo el punto del manual donde lo explica.
Está en ingles.
Si necesitas traducción me lo dices
Wing Mixing Type Selection
There are two different wing mixing functions to select from:
V-tail mixing
Intended for V-tail aircraft (such as a Beechcraft Bonanza), V -tail mixing allows the
ruddervators to operate both as rudders and elevators. V -tail mixing requires that
each ruddervator be operated by a separate servo.
To activate V-tail mixing:
1. Connect the left ruddervator servo to channel 2 (elevator) in the receiver and
connect the right ruddervator servo to channel 4 (rudder) in the receiver.
2. Enter the programming mode. Access the “WING” screen with the MODE key.
3. Push the DATA INPUT lever upward or downward for about a half second to select the V-tail
mixing.
You cannot set “V-tail” mixing when “Elevon” mixing has already been set.
4. Once this mix has been activated, move the servos to their full extremes to make certain they are not overdriving the
controls. If necessary, adjust the linkages to achieve the correct control throws.
Elevon mixing
Intended for tailless, “flying wing” models such as delta wings and flying wings,
elevon mixing mixes channel 1 (aileron) to channel 2 (elevator) allowing the
elevons to operate in unison (as elevators) or in opposition (as ailerons). This
function requires that each elevon be operated by a separate servo.
To activate elevon mixing:
1. Connect the servo in the right wing to channel 2 (elevator) in the receiver and connect the
servo in the left wing to channel 1 (aileron) in the receiver.
Elevon mixing.
You cannot set “Elevon” mixing when “V-TL” mixing has already been set.
"Quod non necat, firmat"
"Omne volat, devolverit"
Solo Star Reconstruido.
Futaba 4 + 1 EXA (Fm35/2,4 ghz)
