- Vie, 27 Abr 2007 12:51
#458677
Taranis X9D Plus SE 2019
https://ales254.wordpress.com/
https://pilonracer.wordpress.com/
http://rcvortices.blogspot.com.es/
F5J-FAI Milvus HM
Stinger
Stiletto
Daidalos 1.2
Pandion 2,54
-Club Aeromodelisme Tarrega
-Club arc Santa Agnes
Hola tengo un planeador que con un power-600 de escobillas y reductora no levanta el planeador que esta sobre 1700 en orden de vuelo y quiero poner un brusles que tire de el olgadamente sin reductora. Como no tengo ni idea de electricos he encontrado este equipo y me gustaria que alguien me dijese si es apropiado o esta mal elegido.
Motor:
HXT35-42B-1100
HXT 35-42B 1100kv Brushless Outrunner (Eq: 2820)
A good sized motor with an excellent finish and quality internals.
Model: HXT35-42B
Input Voltage : 7.4V~14.8V (2~4S Li-po)
Kv : 1100 rpm/V within 10%
Current capacity : 45A/30s
Dimensions : 35mm X 42mm / 1.38in X 1.65in
Shaft diameter : 4mm / 0.16in
Weight : 132g
Number of poles/magnets : 14
Recommended model weight : 1000~2300g / 35~81oz
Power equivalent : .32,2stroke
Suggested prop size: 11x8
Variador:
HW_P40A
H-Wing Pentium 40amp Speed Controller
Pentium 40A Brushless Speed Controller
The pentium series ESC are a very good quality controller. They have a broad range of programming features and a smooth throttle response compared to other BESCs in the same price range.
This BESC can handle 3A continuous current which is great for larger planes with bigger servos.
Cont Current: 40A
Burst Current: 55A
BEC Mode: Linear
BEC : 5v / 3A
Lipo Cells: 2-6
NiMH : 5-18
Weight: 33g
User Programmable, both via controller and optional programming card. The programming card is an excellent item as it instantly tells the user the current settings and with a few simple clicks of the buttons, the user can change the settings and have graphical reassurance of those changes.
The programming card is an excellent Item and simple to use!
Bateria:
Li-Poly
HXT17003S
HXT D9 1700mAh 11.1v 20-30C Lipo Pack
Pack Dimentions : 24x34x83mm
Pack Weight : 143grams (20C, true weight)
Capacity : 1700mAh+
[/b]
Motor:
HXT35-42B-1100
Model: HXT35-42B
Weight : 132g
Variador:
HW_P40A
Cont Current: 40A
Burst Current: 55A
BEC Mode: Linear
BEC : 5v / 3A
Lipo Cells: 2-6
NiMH : 5-18
Weight: 33g
Bateria:
Li-Poly
HXT17003S
Capacity : 1700mAh+
[/b]
F5J-FAI Milvus HM
Stinger
Stiletto
Daidalos 1.2
Pandion 2,54
