- Mié, 11 Abr 2007 6:34
#448138
dentro de unos dias tendre este parato, es un regalo. las fotos no pertenecen al avion ya que el mio sera en la caja, sin motor ni electronica. pero para daros una idea del modelo que digo es el phoenix model
alguno lo a volado ? configuracion correcta ?
motor: GMS 47 ABC BB
FEATURES: Ball bearing-supported crankshaft
Front-mounted High Speed needle valve
Low Speed needle-equipped carburetor
Aluminum Brass Chrome piston/sleeve construction
Adjustable exhaust outlet on muffler allows 360° rotation of
muffler tip
Gold anodized heatsink head
One piece crankcase with a bead-blasted finish
2 year warranty on all GMS engines
INCLUDES: One .47 airplane engine
One bolt-through muffler
One carburetor
One muffler gasket
One glow plug
Two allen key tools
Two muffler screws
One manual and parts list
REQUIRES: Attaching High Speed remote needle valve and muffler.
5-15% airplane nitro fuel.
10x7 break-in propeller
SPECS: Displacement: .47 cid (7.72cc)
Bore: 22.4mm
Stroke: 19.6mm
Output: 1.47 BHP at 15,000 RPM
Practical range: 2,000 - 16,000 RPM
Weight: 475g (with muffler)
Center distance width across mounting holes: 1.7" (44mm)
Center distance length of mounting holes on same side: 0.69" (17.5mm)
Length from front of crankcase to backplate screws: 3.4" (87.3mm)
Width across mounting flanges: 2.0" (51.5mm)
Total height of engine: 3.43" (87.3mm)
Length from center of head to front of crankcase: 2.4" (61.8mm)
Widest width of crankcase neglecting mounting flanges: 1.4" (35.7mm)
Length from front of crankcase to center distance of front
mounting hole: 2.1" (53mm)
Height from crankshaft center to top of head: 2.8" (71.2mm)
Crankshaft thread size: 1/4-28
COMMENTS: Sport Model: 10x7, 11x6
Racing Model: 9x6
Scale Model: 11x6
muffler tip
One carburetor
One muffler gasket
One glow plug
Two allen key tools
Two muffler screws
Bore: 22.4mm
Stroke: 19.6mm
Racing Model: 9x6
Scale Model: 11x6
creo que le metere este motor- ¿ bien?
helice APC11X6
GSM. 47 ABC BB.jpg (10.5 KiB) Visto 1699 veces
helice APC11X6
Última edición por tinomarper el Jue, 07 Jun 2007 14:03, editado 2 veces en total.
