- Mar, 27 May 2014 0:23
#1278504
Hola a todos
tengo un motor nuevo sin uso un Turnigi Park480 de 850kv , unos servos de 9gr y un variador de 40a, habia pensado meterselo a un Gemini de Multiplex,
Se quedara corto el motor, aqui dejo las caracteristicas
Spec.
Battery: 2~3 Cell /7.4~11.1V
RPM: 850kv
Max current: 28A
No load current: 11V/0.9A
Internal resistance: 0.09 ohm
Weight: 80g (not including connectors)
Diameter of shaft: 4mm
Dimensions: 34.7x36.9mm
Required:
30A~35A ESC
Test Data @ 11.1v:
9x5 - 8.6A - 650g Thrust
10x4.7 - 11.5A - 860g Thrust
11x4.7 - 19.5A - 1140g Thrust
Dagon
Spec.
RPM: 850kv
Max current: 28A
Required:
30A~35A ESC
Test Data @ 11.1v:
Dagon
