Ralph Okon (a.k.a. www.powerditto.de ) is putting together a group order for 40mm. diameter, 18pole statorlaminations. A minimum order of 5000 laminations is needed to start a production run. Minimum order per person is 50. One 0.20mm lamination (NO20 iron quality) will cost 0.5€. Flux ring and frontplates will probably also be available by then. Keep in mind, this is not a business for Ralph, he's in the business of curing people :-)
More info on ordering;
www.rcgroups.com/forums/showthread.php?t=392627
I'll post this in several lists/forums, think it's best if we all discussed/asked in the thread above.
Por ron_van_sommeren
#85038
Rahlp Okon a.ka. powerditto escribió:I think, you should better calculate with ca. 4 per mm, because of the needed insulation between the plates. in summery 40 up to 45 per cm I think.
we are looking now for curved magnets for the project.
it seems, if there are enough users who join the project,
ist could give a complete set (can, bearings, etc.) for the motor.
lenght then 5, 10 and 15mm in first attempt.
and the baby has a name now:
its our "CROCODILE"
-has many teeth too, more then the others :D
-seems to be leazy, but is a very powerfull animal.
- there are big elektrical lokomotives(?) for railway, also named so:
http://www.ozdoba.net/rhb/croco_d.html
if you are interested in more details, please have a look at
http://www.powerditto.de/crocodile-project.html
we have orders for 2000 statorplates now and we need minimum 5000 to get this very good price.....
viele grüsse,
ralph
#86929
Turned parts, magnets, shafts, ball bearings will be available too. See:
English
http://www.powerditto.de/crocodile-projectengl.html
Deutsch
http://www.rclineforum.de/forum/thread. ... er=&page=4
Remember, this is not a commercial thing, it's a group design project from the diy motor builders at
http://www.rclineforum.de/forum/board.php?boardid=29
