- Lun, 07 May 2007 0:53
#464263
Hola:
Mirando por foros extranjeros he encontrado a uno que dice haber logrado la forma de conseguir que el T-Rex de la misma sensación de vuelo de heli tipo 30 que el Mini Titán tiene.
No entiendo muy bien a qué se refiere, algo de invertir el plato cíclico, os lo pongo directamente en inglés y si alguien se anima a probar que nos diga:
All you need to do to make you TRex fly like the better flying Mini Titan is reverse evrything north of the swash plate... This will turn your blade grips over, making the links be on the leading edge rather than the trailing edge... This is what makes the Mini T fly like a bigger heli... Try it, it works... The swash movment down will now give positive pitch, so you will need to reverse that on your radio... Let me know what you think... Enjoy..
The secret behind the superb flight characteristics is the blade grips have the links on the leading edge... Rather than fighting the wind from behind, it adjust the front edge of the blades which like your hand outside of a car window, is silky smooth... Just some free info for people to make there TRex's even better than they already are...
La url original es:
http://www.runryder.com/helicopter/t344044p1/
Saludos.[/i]
La url original es:
Saludos.[/i]
