- Dom, 09 Feb 2014 20:16
#1262192
Buenas a todos , abro este post para comentar el helicóptero que mande a pedir y comentar sobre dicho modelo. e visto que en español hay poca información de este modelo en si y e pensado documentarlo .. cuando me lo traigan sacare unas fotos y un vídeo analizando sus piezas .
me costo unos 300€ heli + envio ... compre unas lipo de 3300 30c (2) y un cargador doble y un taka-taka , las lipos las vi muy ligeras 531g y de gran capacidad ....
estaré a la espera pero no pienso volarlo hasta estar seguro que esta configurado y practicar con el simulador . tb el taka-taka ayudara ...
a la espera del transto , mientras pongo su ficha tecnica
Specification:
Fuselage length:850mm(33.5 inches)
Fuselage height:310mm(12.7 inches)
Main blade length:425mm(16.7 inches)
Main rotor diameter:970mm(38.2 inches)
Tail rotor diameter:150mm(5.9 inches)
Motor pinion gear:12/13T
Main drive gear:162T
Tail drive gear:145T
Tail wing drive gear:31T
Drive gear ratio:1:13.5:4.68/1:12.46:4.68
Unladen weight:900g(1.98 lb)
Weight:1700~1750g(3.75 ~3.86lb)
Features:
1.You can take the helicopter out of the box and fly with it
without any adjustments(RTF).
2. 80% of the kits components are manufactured from rigid high
precision aluminum alloy.
3. you can simultaneously control 3 servo’s for control system .It’s
great for 3D flying and extending the life cycle of servos.
4. Uses a fly-bar weight to provide a more stable flight and sensitivity.
5. carbon fiber frame , which is strong and light for flight.
6. Auto-Rotation System and CNC Metal tail unit and tail holder are
manufactured from rigid aluminum, giving a greater lifespan and
reliability.
7. Equipped with three 26g swash plate servos and one 26g
digital lock tail servo
Package include:
1 x RC 500 electric helicopter
1 x 500 glass fiber canopy
2 x 425mm glass fiber blades(one pair)
1 x 6CH remote control(require eight 1.5v “AA” batteries but not
include)
1 x 6CH receiver
1 x X500kv1600 brushless motor
1 x 60A brushless ESC
1 x 720 gyro
3 x 25g swash plate servo
1 x 26g digital tail servo
1 x 2600mah 22.2v 25c lipo battery
ya abri un hilo de presentación , pero saludos a todos , espero aportar algo a la comunidad
Specification:
Features:
reliability.
Package include:
include)
1 x 6CH receiver
1 x 720 gyro
