Si buscas la acción al máximo, y poner la adrenalina a tope, con esta nave podrás hacerlo.
Mira que maquinon!!!
Link de compra: http://www.gearbest.com/rc-helicopters/pp_295459.html
Características:
- With flybarless head rotor set. 6061T aluminum precision CNC processing technic, equipped with silver-red present more high fidelity. Rotor head using 5mm-diameter spindle shaft and 8mm-diameter main shaft.
- With FBL pros and cons linkage rod, metal dual-bearing swash plate.
- With all-metal swashplate servo mount, accurate fixed position, apply to most commercially micro swashplate servo.
- Improved with all-metal 5 fixed points motor mount.
- Big battery compartment and slide-way design, more convenient for install and disassemble. Wide selection of batteries with different capacities 6S 1500 - 2600mAh.
- Plastic locked rudder servo mount, apply to medium-sized servo.
- Adapting Japan imported UNITTA or America imported GATES synchronized conveyor belt.
- With magnetic quick release canopy mounting bolt.
- New improved 1.5mm carbon fiber compound frame, over 90 percent of screw using Taiwan Fang Sheng 12.9 - Class socket button head screw,equipped with red aluminum screw washer.
- With all-metal gyro mount.
- Improved and thickened carbon fiber tail boom.
- New design of metal tail torque tube set, metal tail rotor control tie rod ball, improved tail holder set, apply to most commercially 5mm tail blade. ( That is 500-Class tail blade )
- With metal tail rotor control arm assembly.
- Streamline fiberglass painting canopy combo.
