Por jesus-1
#322334
necesito saber si el motor Brushless HC3516-1350 FUNCIONA CON LIPOS DE 7,4 O 11.1 ES MULTIPLEX
Por manuelcasaas
#323093
Características del Motor Himax HC3516-1350:
Weight: 134g, (4.7oz), Motor only
Max Power: 350W, (This is dependent on several factors)
Max RPM: 20,000 RPM
Diameter: 35.2mm, (1.39”)
Length: mm, 42.2mm(1.66”)
Shaft Diameter: 5.0mm (.1969”)
Mount Screw Thread: 4-40, max depth 5mm, on 25mm, (1.0”) circle
Maximum Case Temperature: 65oC, (149oF)
Electrical Specifications:
HC3516-1350 Kv = 1350, Rm = .023, Io = 2.3
Efficient Operating Current = 15-40A, 56A Max 15 seconds
Recommended Accesories:
45 or 60 Amp Brushless Speed Control
7.4-11.1V Lithium Polymer or 7-10 Cell NiCd or NiMH Battery, ca-pable of 40-56 Amps
Información:
http://www.allerc.com/product_info.php? ... b0b70e3947...
