- Lun, 05 Sep 2016 14:30
#1355867
Otra alternativa para poder hacer vuelos de carreras y este kit os viene con todo lo necesario.
[youtube]http://www.youtube.com/watch?v=x5BSC2FHv7c[/youtube]
Link de compra: http://www.gearbest.com/multi-rotor-par ... tml?wid=21
Main Features:
Race level flight control: Skyline32 Acro
Brushless motor: RS2205 2600KV (4pcs)
Brushless ESC: Lightning 20A (4pcs)
Rotor specifications: Standard 4045 propeller (8pcs)
Camera: PAL standard CMOS 800TVL (1pc)
Transmitter: 5.8G 40CH 600mW
5.8G mushroom antenna: Greatly increases video and audio signal
Lithium-polymer battery: 11.1V 1300mAh lithium polymer battery (included)
Specifications:
Quadcopter:
Flying time: 8 - 15 minutes
Charging time: 120 minutes
Control distance: 500m
Channel: 6
Skyline32 Acro Flight Controller:
- The Skyline32 Acro flight controller with its Cleanflight and Baseflight (NAZE32 firmware) support brings to you the innovation only available from the ever-growing open source community
- The Skyline32 Acro supports OSC and OLED functions and is compatible with Spektrum satellite receivers for added versatility
- This compact flight controller is perfect for all multi-rotors whatever their size, but is particularly suited to smaller models
- RC input: Standard, CPPM (PPM SUM)
- Processor: 32-bit ARM
- Voltage: 3.3V
- Frequency: 72MHz
- Weight: 4.5g (No wires)
Lightning 20A ESC:
- The first BLHeli ESC with synchronous rectification hardware design in the market
- Utilizes high-performance F396 MCU
- Supports Active Braking, Oneshot Enabled, Multishot
- FW upgradable via signal wire
- Anti-counterfeit code of authenticity
- Supports up to 4S high voltage (4.35V max. per cell)
- Smallest F396 powered 20A ESC
- High-current burst rating
- Lightweight: 4.78g
- Size: 24.5 x 12.5 x 5.0 mm
Notice: there are 3 different colors of quadcopter's propeller, we will ship one color of it for you randomly.
Main Features:
Specifications:
Quadcopter:
Channel: 6
- Voltage: 3.3V
- Frequency: 72MHz
Lightning 20A ESC:
