Por Gearbest
#1353979
Buenas si buscas algo bueno para montar tu mismo esta opcion es una muy buena alternativa.
https://www.youtube.com/watch?v=iURdanOCFIA
Link de compra: http://shrsl.com/?dg0u
Lens seat pitch ( support CCD, CMOS camera board aircraft )
Upper body version with a plurality of antenna holes to facilitate fixed antenna
Body with 1.5MM 3K full carbon fiber
Rational layout, easy to install
ESC can be installed in arm, it can also be installed in the fuselage
Compatible AOMWAY 700 line camera mounts
Diagonal Wheelbase: 210mm
Rack Weight: 80g
Support Motor: 1306 KV3000 / 1804 KV2300 / 1806 KV2300 ( 1806 / 4045 recommend inch paddle )
Motor Diameter: 27.9mm
Motor Height: 31.7mm
Support Propeller: 4 / 5 inch
Mounting Dimension: 200 x 165 x 62mm
Net Weight: 91g
Warm Remind:
Battery serviceable range: 3S 8.4V - 12.6V 1300-1500mAh 30C.
If the battery sessions which you use are above 4S, please change the battery as 30A ESC.
