- Sab, 22 Mar 2008 19:14
#643345
Hola seman! que pasa tio?, ya veo que te has ido a lo más grande no?, aver si pronto vemos ese avion volar!! jejeje...
... bueno respecto a tu pregunta he encontrado esto:
Always use battery cells of the same type. We recommend that you use batteries with a capacity of at least 1700 mAh; for larger models we suggest packs of up to 3000 mAh capacity. You can use either Nickel-Cadmium batteries (NiCd), Nickel-Metal-Hydride batteries (NiMH) or
Lithium-Polymer batteries.
We strongly recommend our own range of high-quality batteries which are designed to be suitable for a wide range of applications in modelling. We particularly recommend our Lithium-Polymer battery packs with integral safety and charge electronics. These are based exclusively on the latest cells made by IONITY AG of Germany.
Para mi poco ingles entiendo que siempre has de usar iguales baterías, con capacidad de minimo de 1700mA y para modelos mas grandes sugiere de 3000mA. Aparte tambien puedes usar de otro tipo de baterías no tiene porque ser de li-po.
Fuente:
http://www.modellbau-deutsch.com/shared ... ch_neu.pdf
"Si quieres que vuele más, tiralo desde mas alto"
-JR 9 canales, AR6200 dual a 2,4Ghz
-Trex 500 3GX.
-Avion Katana 1,5m.
