Por Gearbest
#1356148
Vuela con total tranquilidad con este mini multi, ideal para hacer indor, aunque claro, para fuera tambien vale.
Link de compra: http://shrsl.com/?dvv5
Description:
The 105mm quadcopter is based on F3 brushed flight controller, which offers you fascinating manual operation. It is flexible in supporting DSM2 and DSMX transmitter and allowing for refits.
Main Features:
- Amazing manual control
The moment you get the control of the drone, you'd be impressed by the excellent performance of its F3 brushed flight controller.
- Compact and lightweight
The 105mm premium carbon fiber frame and the application of coreless motors contribute to the agility of the drone. While the integration of 520TVL FPV camera, 32-channel transmitter module, and 5.8G antenna facilitates the installation process for future use.
- Great flexibility
The quadcopter is compatible with DSM2 / DSMX remote control. More importantly, the flight controller supports 2S power supply, which provides great refit possibility.
Specifications:
Motor diameter: 8.5mm
Motor height: 20mm
Output shaft diameter: 1.0mm
Output shaft length: 5mm
Weight: 5g
Voltage: 3 - 5V
Current: 0.15A
RPM: 35000-37000 ( 3V ), 50000 ( 5V )
Propeller length: 60mm
