- Sab, 05 May 2007 1:16
#463160
Hola:
Ahi va lo que dice la pagina web
SPECS: Displacement: 0.545 cu in (8.93cc)
Bore: .906 in (23mm)
Stroke: 0.846" (21.5mm)
Practical RPM: 2,000-17,000
Power Output: 1.75 ps/16,000 RPM
Weight: 14.25oz (404g)
Recommended Props: 12x7-8, 13x6-7
Crankshaft thread size:1/4-28
Distance/remote needle to end of crankshaft: 4.7" (119.4mm)
Distance from center of engine to drive hub: 2.4" (60.4mm)
Distance from center of engine to end of crankshaft: 3.4" (87.6mm)
Distance/crankshaft center to muffler exhaust outlet: 3.9" (100.5mm)
Height from crankcase bottom to top of cylinder head: 3.3" (85.2mm)
Height/crankshaft center to top of cylinder head: 2.6" (67.4mm)
Width including mounting tabs: 2" (51mm)
Width not including mounting tabs: 1.4" (35mm)
Width between mounting holes same side: 0.69" (17.5mm)
Width between mounting holes opposite side: 1.7" (44mm)"
Diameter of muffler body: 1.5" (38.1mm)
Angle of muffler in relation to engine: 4°
Dario
Saludos de un marplatense desde Parque de los Patricios, Buenos Aires, Argentina
