- Dom, 02 Abr 2006 13:46
#212747
bajate el programa moto calc y miralo tu mismo de todas formas te hago yo la tabla pues es un poco jodido de manejar pero bajatelo y te vas haciendo con el ok
Cells = 2
Gear Ratio = 1,00
Diam (in) = 6,0
Pitch (in) = 3,0
Weight (oz) = 37,8
Batt Amps = 7,3
Motor Amps = 7,3
Motor Volts = 7,3
Input (W) = 53,3
InPLd (W/lb) = 22,6
Loss (W) = 22,5
MGbOut (W) = 30,8
OutPLd (W/lb) = 13,0
MotGb Ef(%) = 57,8
Shaft Ef(%) = 57,1
Prop RPM = 11612
Thrust (oz) = 7,1
PSpd (mph) = 33,0
RofC (fpm) = 60
Time (m:s) = 14:01
con3s
Motor: Jamara Pro 480; 2445rpm/V; 0,8A no-load; 0,31 Ohms.
Battery: Sanyo 1700SCR; 2 to 3 cells; 1700mAh @ 3,7V; 0,004 Ohms/cell.
Speed Control: Astro 210; 0,003 Ohms; High rate.
Drive System: Graupner 6x3 Folding Prop; 6x3 (Pconst=1,31; Tconst=0,95) direct drive.
Airframe: Great Planes Spectra; 676sq.in; 37,8 to 39,7oz RTF; 8 to 8,5oz/sq.ft; Cd=0,045; Cl=0,48; Clopt=0,64; Clmax=1,07.
Filter: 30A max (per Motor); 45A max (per ESC).
Conditions: Sea Level, 29,92inHg, 59°F
Cells = 3
Gear Ratio = 1,00
Diam (in) = 6,0
Pitch (in) = 3,0
Weight (oz) = 39,7
Batt Amps = 11,0
Motor Amps = 11,0
Motor Volts = 10,9
Input (W) = 120,4
InPLd (W/lb) = 48,6
Loss (W) = 59,5
MGbOut (W) = 60,9
OutPLd (W/lb) = 24,6
MotGb Ef(%) = 50,6
Shaft Ef(%) = 49,8
Prop RPM = 14582
Thrust (oz) = 11,2
PSpd (mph) = 41,4
RofC (fpm) = 214
Time (m:s) = 9:16
esta es la mejor configuracion helice 6x3 motor 480 3s lipo
electro stik.druine.fw190.wat200.tigher trainer.wyfarer.tango.hawk1400.cierzo.piperj3elec.diomedea 4mts.af10thunderbolt.space scooter.elect-j.dhc2.rafale.
