Por fernanbs
#968339
Hola, me encanta este avion y creo que es una maqueta de foam muy conseguida, empiezo este post por si alguien lo tiene, y si no cuando me decida y lo compre empezare a poner mis impresiones.
Todavia no se si lo voy a comprar completo o sin electronica.
-Specs
Wingspan: 43.5 in (1105mm)
Overall Length: 39.4 in (1000mm)
Flying Weight: 35.3 oz (1000 g)
Motor Size: 15-size 720Kv brushless
Speed Control : EFL 30A Switch-Mode BEC BL
Recommended Battery: 11.1V 3S 1800–2200mAh Lithium Polymer
Landing Gear: Fixed main LG and steerable tail wheel
-Key Features
4 channels to provide maximum control and flight performance for advanced maneuvers
15-size outrunner brushless power system for increased efficiency and power
Molded servo pockets for optional flaps
3-blade prop and spinner with 2-blade spinner option
Scale landing gear
Historic trim scheme inspired by Erich Hartmann—Germany's leading WWII ace
Steerable tail wheel installed
Durable and lightweight Z-Foam™ construction
Dual aileron servos for precise control
-Overview
Fast, agile and armed to the teeth, Willy Messerschmitt’s BF-109 dominated European skies at the outset of World War II. With the exception of Britain’s Spitfire, the “109” outclassed nearly every other fighter it faced between 1939 and 1941. In that short time, its pilots, many of whom had honed their tactics in the Spanish Civil War, racked up thousands of aerial victories. Now anyone can experience the thrill of flying the Messerschmitt on a smaller scale with this fully aerobatic, brushless-powered Plug-N-Play® reproduction from ParkZone.
Bf-109G PNP already has the 3-wire servos, a ParkZone 15-size low Kv outrunner brushless motor, and an E-flite® 30A brushless ESC. The decals have already been applied, as well.
Por fernanbs
#968341
Por HARENNA
#968388
HOLA fernanbs¡¡ sabes si alguien ha comprado en esta pagina. o si tu has comprado ? el avion es guapisimo no se si es foam o epp.¡¡ son 179.99 dolares pero hay que saber si en aduana se paga mas impuestos.¡¡ porqe creo que estan metiendo mas impuestos de aduanas a los paquetes que vienen de estados unidos. no lo se ... tu sabrias algo respecto a esto.¡¡ :| .. segun he leido te lo sirven sin electronica a este precio. :arrow:
saludos.
Por fernanbs
#968540
El avion completo son 180$, viene con toda la electronica excepto receptor, y el otro 80$ sin electronica; por 100$ de diferencia puedo comprar mucha electronica china o sin ser china tambien.
Yo no he comprado en esa pagina ni se cuanto cobran de gastos de envio, estoy buscando otras a ver si lo veo mas barato o que sean europeas.
Por juan
#993716
Por 136 eur envio incluido lo tienes en la pagina del enlace que te pongo con motor/regulador y servos instalados,poner receptor y bateria y a volar,es una pagina seria de Austria y no vas a tener problemas de aduana.la verdad es que el corchete esta guapo yo tengo uno spitfire de Parkzone y vuela francamente bien para el tipo de avion que es
http://shop.lindinger.at/product_info.p ... s_id=81399
Por HARENNA
#994337
Esa pagina que pones es en aleman o sea una tienda de europa.?
esta muy bien el precio , lo que hay que ver cuantos portes te calcan por ponerlo en tu casa.¡
Por juan
#994365
compi lee bien puse 136 eur envio incluido,los portes son de 6 eur tarifa plana y si pides mas de 90 eur?? el envio es gratuito,la tienda esta ubicada en Austria y funciona muy bien,de hecho hoy he recibido cuatro pijadas que pedi por el monto de 30 eur y en una semana mas menos lo tenia en casa
Por fernanbs
#1182549
por fin lo tengo!!!!!
voy a ir montando y ya contare detalles
Por fernanbs
#1201710
Después de haber reforzado el fuselaje con tubo de carbono, haber hecho la bancada de motor y ajustar, colocar electronica,instalar luces de navegación, retocar algunos huecos con epoxi y pintura, modificar la cabina e instalarle antenas, aqui van unas fotos:
