- Jue, 02 Abr 2009 21:31
#819414
Voy a adquirir uno, será mi primer 3d, queria saber que motor le biene bien y que elices y bateria debería de meterle.
Que os parece este motor?
Battery Current capacity:
16A/60s
RPM/V :
1534rpm/v
Max Currect: 15.2A
Max. efficiency current :
7 -16 A(>75%) 82%
No load current :
10 V: 0.9 A
Shaft diameter :
3 mm
Dimensions :
22 x 10 mm
Internal Resistance: 0.15 ohm
Weight :
41 g
Recommended model :
200 - 800 g
Recommended Rotor Blade:
7 x 6 to 10 x 5
prop without gearbox: 5 - 7inches
16A/60s
RPM/V :
1534rpm/v
Max Currect: 15.2A
7 -16 A(>75%) 82%
No load current :
10 V: 0.9 A
Shaft diameter :
3 mm
Dimensions :
22 x 10 mm
Weight :
41 g
Recommended model :
200 - 800 g
7 x 6 to 10 x 5
EasyGlider con Flaps
Mini Piper
Mini Piper
