Por ron_van_sommeren
#4713
Michele escribió:\BTW, what do you think about new Aircraft World's DIY motor kits?
I haven't seen any user reports yet but they certainly are a step up from plain modified cd-rom motors.
Por Javier B
#4725
Hi Ron:
Do you know the theorical maximun trust for a CD-rom engine with direct drive? The prop doesn´t matter.
Thank you
Regards.
Javier B.
#4732
Javier, you could have a look at the tables in the last pages of the assembly manual, that should give you some indication:
http://www.eflypower.com/mini2.pdf
The same goes for the database at www.gobrushless.com:
-> research and development
-> performance database
Also LOT's of ongoing discussion and results in the 'power systems' subforum over at www.ezonemag.com but you probably already noticed that:
http://www.rcgroups.com/forums/index.php?topic=air-elec
