Por ron_van_sommeren
#126044
This new e-flight calculator has a choice (switch) between German and English language:
http://www.elektromodellflug.de
-> datenbank
-> antriebsrechner
Download the zipfile, run the spreadsheet and select your language using the buttons in the upperrighthand corner.
More info on the usage of the calculator and English download:
http://www.badcock.net/drive_calculator/
Example:
http://goldeneye.ethz.ch/motoren/electr ... t/index_EN
If you want to translate the other articles/items on said site, you can use e.g. http://translate.google.com/translate_t
Última edición por ron_van_sommeren el Mar, 29 Nov 2005 21:45, editado 1 vez en total.
Por Enrique González
#126137
¡Gracias Ron!
Veo que tu español mejora tanto como mi inglés. :wink:
#126152
¡Ah, ladrón!
¡¡¡Tu dominas el idioma, pero eres un vago!!! :wink: :wink: :wink:
¡Gracias de nuevo, por tus interesantes apuntes sobre temas eléctricos!
#135711
If you want to be kept up to date about new 'Drive Calculator' software/motordatabase releases or if you want to join the discussion, subscribe to this new mailing list I set up:
http://www.yahoogroups.com/group/D-calc
It would be nice to see a bi-lingual group, English and German.
Mail reception can be disabled and enabled again (e.g. during holidays) but messages can always be read in the public archives on the aforementioned homepage. The group has a RSS/XML feed
I took care of spammers, the way I did for 'my' diy brushless motor group (famous last words ;) )
Subscription either via the homepage or by sending an empty message to
D-calc-subscribe@yahoogroups.com
#145357
Version 2.2, motordatabase version 11 is available.
New features:
Correction for air density, temperature and height.
New motors in database
- Kora15-16
- AXI2212-20
- Python 3s
- Python 3s
- Python 200
- SS23 (T-Rex Suchtmotor)
- CDR250x20-50Y Heinrich Hilgers Motor (15g)
- next: Kora10-10/12
Download, English language default
Download, German language default
http://www.elektromodellflug.de/
-> Datenbank
-> Antriebsrechner / Drive calculator
Direct link to file download
http://www.elektromodellflug.de/Uploads ... 22_011.zip
#183334
A new version of the Drive Calculator program is available, software version 2.21, motordatabase version 012. English and German version downloads via the two links at www.yahoogroups.com/group/D-calc
Motors added to the database:
- Hyperion Z3007-26
- Hyperion Z3025-6
- SHP SS10/14 (-> Kantanamotor)
- AXI 2204/54 (new:6,5mm bell)
- Kontronk Kora 10-10
- Kontronik Kora 10-12
