- Sab, 02 May 2009 12:41
#831706
Código: Seleccionar todo
Y la traduccion googlera seria mas o menos asiMay 1st 2009
New update announced:
Phoenix v 2.5
We are pleased to be able to announce the full list of features for the next update.
As usual this will be a completely free update to our existing customers.
New Features
• Store model's current position for reset point - default hotkey 'S'
• "Throttle, Rudder and Elevator" option added to Torque Trainer
• Added ability to fly with tutorial recordings, and to "free-look" with your mouse
• Added ability to slow down or speed up tutorial recordings
• Added Cut/Restart Engine control for all model types
• Advanced control over helicopter governor speed using throttle position
• Assign a different control profile to individual models
• Sounds:
__ • More sounds of impact, collision and scrapes with environment
__ • New ambient environmental sounds
__ • Reverb effects in interior locations
Improvements
• Physics:
__ • Crisper, more responsive collective
__ • More accurate blade physics:
__ __ • Blade stops
__ __ • Spool-up times
__ • More accurate autorotation physics
__ • Scale fixed-wing models diplay more accurate torque effects on takeoff
__ • F3A pattern planes trim corrected when inverted
__ • More pronounced roll effects when applying rudder to fixed-wing models
• Sound:
__ • Selectable engine-type for all models
__ • All helicopter sound effects resampled
__ • All fixed-wing sound effects resampled
• Graphics:
__ • New rotor/propeller effects for greater realism
__ • Improved wakes and ripples in water
__ • New splash effect when objects impact with water
__ • New rotor ripple effect
__ • New streamer texture
__ • Streamer width scales with model size
__ • Helicopter rotor blades change with collective
__ • Training undercarriage materials improved
__ • Extra debris when a breakage/crash occurs
• PhoenixUpdate:
__ • One-click update to the latest software version
__ • Now downloads in the background - fly while your updates download
__ • Better handling of failed downloads
• PhoenixOnline:
__ • New multiplayer engine
__ • Faster and less lag
__ • Improved connection reliability
__ • Voice-chat with selective muting, auto-voice-sensing and noise filtering capability
__ • Messenger widget for session management
__ • Improved session lobby with chat
__ • Pilots/training undercarriage now functions online
• User Interface:
__ • Numerous improvements and optimisations to the User Interface layout
__ • Ability to disable auto-reset during training modes
__ • Improved failures/fuel empty/crashed icons/display
__ • Minimise flight recorder to a smaller footprint, which autohides
__ • Training gear now appears under Select/Edit model screens
__ • Various editable attributes now enable/disable depending on other options selected
__ • Re-show help/warning messages using the Program Setup > General menu
• Languages:
__ • Czech language added
__ • Hungarian language added
• Updated manuals added for:
__ • French
__ • German
__ • Italian
__ • Portuguese
__ • Spanish
__ • Czech
__ • Hungarian
• Walkera 2401 and 2601 control profiles added
Bugs Fixed
• Disabled sound option issues resolved
• Issue with shift-look and binocular view fixed
• Zoom level now saved correctly when the "Reset Zoom" menu is used
• Streamers now function correctly when length is set to less than 10m
• TreeView controls now scroll correctly when expanding items
• Issue with inflight tuning fixed
• P-51 Mustang rudder no longer breaks on startup
• PhoenixUpdate: "Select all" does not select installed updates (unless shown)
• PhoenixUpdate now takes alternate "SETTINGSPATH" for users without a My Documents folder
• Fixed an issue with competition bomb scoring
• Left wheel on max 3d not textured correctly
• Error starting with window minimised fixed
• Issue fixed on fixed-wing models set to zero stabiliser/fin area
• Nightfly planes now all correctly have red lighting on the left and green lighting on the right
• Problems when variants folders when they do not exist
• Improved handling of driver issue with Intel 965 chipsets
• Binocular view now functions during a multiplayer session
• Along with the new update, we also plan to release the following new content:
New Flying Sites
• Montebello Castle - Photographic panoramic flying site
• Lagos Rocks - Photographic panoramic flying site
• Stockholm Bridge - Photographic panoramic flying site
New Models
• Helicopters
__ • Align T-Rex 250
__ • Rave 450
__ • Outrage G5
__ • Outrage G550
__ • Protos 500
__ • Huey UH-1H "Iroquois"
• Fixed Wing
__ • Zivko Edge
__ • Polikarpov I-15
__ • Gambler .40
__ • Cessna 182
__ • Extra 300s
__ • Cap 232
__ • Wot-4 Classic
• Other
__ • BA-609 Tilt-rotor
• Please continue to check our News page for more information as it becomes available
1 de mayo de 2009
Nueva actualización del anuncio:
Phoenix v 2.5
Nos complace poder anunciar la lista completa de características para la próxima actualización.
Como es habitual será una actualización completamente gratuita para nuestros clientes existentes.
Nuevas funciones
• Guarde la posición actual de modelo para reajustar el punto - por defecto la tecla 'S'
• "Acelerador, Timón y Ascensor" opción añadido a Par Entrenador
• Alta capacidad de volar con tutorial grabaciones, y el "libre-look" con el ratón
• Alta capacidad para ralentizar o acelerar el tutorial de grabaciones
• Creado Cortar / reinicio de control del motor para todos los tipos de modelos
• Control avanzado en helicóptero el gobernador de velocidad utilizando la posición del acelerador
• Asignar un perfil de control diferentes para los distintos modelos
• Sonidos:
__ • Más sonidos de impacto, colisión y arañazos con el medio ambiente
__ • Nueva ambiente sonidos ambientales
__ • efectos de reverberación en el interior de los lugares
Mejoras
• Física:
__ • nítidos, colectivos más sensibles
__ • Más precisa cuchilla física:
__ __ • Blade paradas
• __ __ veces hasta la cola -
__ • Más precisa autorotation física
__ • Escala de ala fija diplay modelos más precisos sobre los efectos de par despegue
__ • F3A patrón planos de corte corregido cuando invertida
__ • Más pronunciada rollo efectos en la aplicación de timón a los modelos de ala fija
• Sonido:
__ • Seleccionable motor tipo para todos los modelos
__ • Todos los efectos de sonido de helicópteros resampled
__ • Todos los de ala fija los efectos de sonido resampled
• Gráficos:
__ • Nueva rotor / hélice efectos de una mayor realismo
__ • Mejor despierta y ondas en el agua
__ • Nueva salpicadura efecto cuando los objetos de impacto con el agua
__ • Nueva rotor efecto
__ • Nueva destorcedores textura
__ • Streamer ancho modelo con escalas de tamaño
__ • Helicópteros palas cambio con colectivos
__ • Formación de aterrizaje materiales de
__ • Extra desechos cuando una rotura o accidente se produce
• PhoenixUpdate:
__ • Un clic en actualizar a la última versión del software
__ • Ahora las descargas en segundo plano - mosca mientras descarga las actualizaciones de su
__ • Mejor manejo de las descargas no
• PhoenixOnline:
__ • Nuevo motor multijugador
__ • Más rápido y con menos retraso
__ • Mejora la fiabilidad de conexión
• __-chat de voz con silenciamiento selectivo, de auto-detección de voz y capacidad de filtrado de ruido
__ • Messenger widgets período de sesiones de la gestión
__ • Mejora de hall de entrada con período de sesiones de chat
• Pilotos __ / formación inferior funciona ahora en línea
• Interfaz de usuario:
__ • Numerosas mejoras y optimizaciones para el diseño de la interfaz de usuario
__ • Capacidad para deshabilitar auto-cero durante los modos de formación
__ • Mejoras en los fracasos / combustible vacío / estrelló iconos / pantalla
__ • Minimizar registrador de vuelo a un menor huella, que autohides
__ • Formación artes ahora aparece bajo Seleccionar / Editar modelo de pantallas
__ • Varios atributos editables ahora activar / desactivar la función de otras opciones, seleccione
__ • Volver a mostrar ayuda / mensajes de advertencia mediante el Programa de Configuración> Menú general
• Idiomas:
__ • añadido idioma checo
__ • idioma húngaro añadido
• Actualización de manuales añadido:
__ • francés
__ • Alemán
__ • italiano
__ • Portugués
__ • Español
__ • Checo
__ • húngaro
• Walkera 2401 y 2601 el control de los perfiles añadido
Errores corregidos
• Discapacitados buena opción cuestiones resueltas
• Número de turnos y mirar binocular vista fija
• Nivel de zoom ahora guardado correctamente cuando el "Restablecer Zoom" del menú se utiliza
• Streamers ahora funcionan correctamente cuando se establece la duración a menos de 10m
• controles TreeView ahora correctamente cuando vaya ampliando artículos
• Número fijo de sintonía con bordo
• P-51 Mustang de timón ya no se rompe en el arranque
• PhoenixUpdate: "Seleccionar todo" no selecciona las actualizaciones instaladas (a menos que se muestra)
• PhoenixUpdate ahora tiene alternativa "SETTINGSPATH" para los usuarios sin una carpeta Mis documentos
• solucionado un problema con la bomba de la competencia de puntuación
• Envío de rueda máximo 3d no texturados correctamente
• Error al iniciar minimizado con ventana fija
• Número fijo de modelos de ala fija ponen a cero estabilizador / fin área
• Nightfly aviones ahora correctamente todas las luces rojas a la izquierda y la iluminación verde de la derecha
• Problemas de variantes cuando las carpetas que no existen
• Mejora de manejo de conductor problema con los chipsets Intel 965
• Binoculares vista ahora funciones durante una sesión de varios
• Junto con la nueva actualización, que también tienen previsto poner en libertad al siguiente contenido:
Nueva Flying Sitios
• Castillo de Montebello - fotográficas panorámicas de vuelo sitio
• Lagos Rocas - fotográficas panorámicas de vuelo sitio
• Puente Estocolmo - fotográficas panorámicas de vuelo sitio
Nuevos Modelos
• Helicópteros
__ • Alinee T-Rex 250
__ • Rave 450
__ • Indignación G5
__ • Indignación G550
• Protos __ 500
• ala fija
__ • Zivko borde
__ • Gambler .40
__ • Cessna 182
__ • Extra 300
__ • Cap 232
__ • wot-4 Classic
• Otros
__ • BA-609-inclinación del rotor
• Por favor, siga visitando nuestra página de noticias para obtener más información a medida que se disponga
