- Sab, 08 Ago 2015 14:41
#1323237
Aquí os presentamos una de las mejore opciones para grabar en HD y tener la mejor experiencia FPV, todo al mismo tiempo.
Esta cámara es mitica y cada vez trae las mejoras que simpre se esperan a un precio muy bueno.
Link de compra: http://shrsl.com/?~9gx8
Características técnicas:
1080P full HD video and audio recording
HFOV 131 degree wide view angle
FOV: 1080P / 720p / WVGA 5 - 30fps wide
Resolution: 2304 x 1536, 1920 x 1080, 1280 x 720
TV display ratio: 4:3 / 16:9
Movie flip: 180 degree rotation
Movie sound: Off plus three volume levels
Using time: More than 80 minutes
Loop recording, 5 minutes clips with one second video overlap
Time lapse photos with delays between images
The targeted delay times range from 0.25 to 60 sec
Recording LED toggle
Movie / photo time stamp toggle
Supporting maximum 32GB MicroSD / TF card (not included in the package)
Power on button delay to prevent premature activation while handling
Auto-record when power to the camera is applied, useful for car recorder use
Charging on / off toggle when plugged into a USB data port
Useful for some external USB devices
TV out (PAL or NTSC), including a playback mode
GUI program support for setting the parameters is available
Can be used as a dash camera (start / stop recording)
