- Jue, 11 May 2006 22:01
#233470
Pero este es el mejor T-Rex que se ha hecho, tiene un montón de mejoras, más de las que parece.
Lo copio en Inglés, tal y como lo pone en RcGroups.
Included rotor blades are the latest 325mm PRO woodies and they work extremely well, even for aggressive 3D flying.
Many of the parts have been updated over the XL and are similar to those used on the SE (ie - newer tail pitch control links/slider, stainless steel tail rotor hub, longer carbon tail blades, high strength main and lower ratio tail drive gears that are white in color, etc). It also includes an aluminum head block, motor and battery mounts (battery is mounted higher on the frame like the SE for better CG and aerobatic performance). Plus the direct-to-swash CCPM linkages are much easier to setup and maintain while staying clear of the canopy.
Response regarding this model from those who have seen it has been fantastic, and as some have stated here, its a great blend of XL and SE in ARF form at a very good price. Flight performance is awesome as its nearly as light as an XL (about 1-2 ounces lighter than an SE) but with stiff aluminum frames, direct CCPM linkages and a few other features that make it handle more like an SE.
Vamos.... que me gusta más incluso que el SE, cuesta 199$ que son 155€, si tuviera que comprarme un heli, sin duda sería este.
Juan
