- Lun, 26 Sep 2005 17:45
#113037
Estos son todos los datos de tu motor como ves el pico max durante 30s es de 22 A con lo cual las baterias esta al limite, pero como no creo que con ese peso de avion tengas que volar ni a la mitad de mando es una configuracion bastante buena, lo de las helices yo comprobaria diferntes tipos y mediria los consumos y el tipo de vuelo que te guste, aqui tienes una tabla, pero lo mejor provar.
Voltage range 4-10 cells
RPM per Volt 1,160 RPM/V
Max. Efficiency 82%
Max. Efficiency Current 6-15 A (>75%)
Max. loading 22 A / 30 s
No load Current/8V 1,0 A
Internal resistance 115 mohm
Dimensions 35x31 mm
Shaft Diameter 4 mm
Weight 76 g
Recomended model weight 600 - 1400 g
Propeller range 6 cells 11"x5,5"
7 cells 10"x6"
8 cells 9,5"x5"
High torque brushless motor with rotating drum and high power neodym magnets suitable for models of 400-500 size, and up to 1500g in weight. Hardened shaft have 4mm diameter and is supported by three ball bearings. Due to it’s high torque this motor is capable of turning large propellers with a high level of efficiency and without the need for a gearbox.
Motor Prop. Battery I/A RPM U (V) P- OUT (W) P- IN (W) Efficiency (%)
2808/24 8x4.5 7xRC 1700 9.2 9150 8.2 61 75 81
2808/24 8x4.5 8xRC 1700 10.9 10050 9.2 81 100 81
2808/24 8x4.5 10xRC 1700 15 11890 11.3 134 169 79
2808/24 8.5x5 7xRC 1700 9.6 8880 8.1 63 77 81
2808/24 8.5x5 8xRC 1700 11.7 9850 9.2 86 107 80
2808/24 8.5x5 10xRC 1700 16.1 11610 11.2 141 180 78
2808/24 8.5x6 7xRC 1700 11.4 8480 8.1 73 92 79
2808/24 8.5x6 8xRC 1700 13.8 9350 9.1 98 125 78
2808/24 8.5x6 10xRC 1700 18.6 10910 11 155 204 76
2808/24 9x5 7xRC 1700 11.7 8400 8 74 93 79
2808/24 9x5 8xRC 1700 14.2 9260 9 100 128 78
2808/24 9x5 10xRC 1700 19 10770 11 157 209 75
2808/24 9.5x5 7xRC 1700 14.2 7820 7.9 85 111 78
2808/24 9.5x5 8xRC 1700 16.9 8560 8.9 112 151 74
2808/24 9.5x5 10xRC 1700 22.1 9830 10.7 169 238 71
2808/24 10x6 7xRC 1700 16.1 7360 7.8 92 126 73
2808/24 10x6 8xRC 1700 19 8010 8.8 118 166 71
2808/24 10.5x6 4xRC 1700 8.8 4640 4.7 31 40 76
2808/24 10.5x8 4xRC 1700 10 4410 4.6 34 46 74
