- Mar, 26 Feb 2008 10:18
#631110
Estoy dudando entre estas 2 li-po, bueno dudando no, es que no se cual es mejor, a ver si me podeis decir cual es mejor para comprarmela, es para usarle en un Multiplex Gemini
1. LM Loong max 2250 3S1P 20C Lipo pack
Weight: 186g
Capacity: 2250mAh
Voltage: 3S1P (11.1v) 3 cell
Discharge Rate: 20-30C
Size: 111x24x34mm (including cell spacers for ventilation)
Charge Plug: JST-XH
Discharge: t-connector (Deans style)
2. ABF 2200mAh 11.1v 18-23C Lipoly
Factory over rated, the ABF battery is certainly no star performer. Our tests indicated this pack can handle 39Amp constant drain with 10sec bursts of up to 49Amp without substantial voltage drop, thus making this pack 18C to 23C.
If youre looking for a budget priced 2100mAh pack and dont require more than 39Amps for more than 10second bursts, then this pack would be perfect.
The pack comes with a deans connector and JST-XH plug pre-soldered.
Spec.
Rated Capacity: 2100mAh
Voltage: 11.1v
Rated Discharge: 18-23C
Weight: 160g (with wires & connectors)(yes, quite light)
¿Cual de las 2 es mejor o me servirá mejor para el Gemini?
Weight: 186g
Capacity: 2250mAh
Charge Plug: JST-XH
Spec.
Voltage: 11.1v
